[petsc-users] [petsc-dev] second patch for DMDAVecGetArrayF90
Satish Balay
balay at mcs.anl.gov
Wed Jul 11 16:22:27 CDT 2012
I added the patch to both 3.3 and petsc-dev repos. Hopefully thats easier to use.
Satish
On Wed, 11 Jul 2012, Blaise Bourdin wrote:
> Rectification: clone petsc-3.3, not petsc-dev, of course...
> B
> > There is something fishy in your tree or your build: the patch that Satish sent addressed this issue, but it clearly has not been applied to your tree. The patch I had originally sent contained an error. For instance, F90ARRAY4DACCESSFORTRANADDR was replaced by F90ARRAY4dACCESSFORTRANADDR (note the capitalization of the "d"). These are the symbols that are unresolved in your build.
> > How about starting from a clean state:
> > - rename your current petsc-dev tree
> > - clone petsc-dev from the official tree (BTW, do you really need petsc-dev, and not 3.3?)
> > - apply the patch Satish sent you or, quoting Satich
> >>> edit src/sys/f90-src/f90_cwrap.c and replace all occurrences of 'F90ARRAY4d' with 'F90ARRAY4D'
> > - run configure with your favorite options, then make
> > This should fix your problem.
