[petsc-users] [petsc-dev] second patch for DMDAVecGetArrayF90
Blaise Bourdin
bourdin at lsu.edu
Wed Jul 11 16:12:32 CDT 2012
Rectification: clone petsc-3.3, not petsc-dev, of course...
B
> There is something fishy in your tree or your build: the patch that Satish sent addressed this issue, but it clearly has not been applied to your tree. The patch I had originally sent contained an error. For instance, F90ARRAY4DACCESSFORTRANADDR was replaced by F90ARRAY4dACCESSFORTRANADDR (note the capitalization of the "d"). These are the symbols that are unresolved in your build.
> How about starting from a clean state:
> - rename your current petsc-dev tree
> - clone petsc-dev from the official tree (BTW, do you really need petsc-dev, and not 3.3?)
> - apply the patch Satish sent you or, quoting Satich
>>> edit src/sys/f90-src/f90_cwrap.c and replace all occurrences of 'F90ARRAY4d' with 'F90ARRAY4D'
> - run configure with your favorite options, then make
> This should fix your problem.
Department of Mathematics and Center for Computation & Technology
Louisiana State University, Baton Rouge, LA 70803, USA
Tel. +1 (225) 578 1612, Fax +1 (225) 578 4276 http://www.math.lsu.edu/~bourdin
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120711/aa046b61/attachment.html>
