[petsc-users] [petsc-dev] second patch for DMDAVecGetArrayF90
TAY wee-beng zonexo at gmail.com
Thu Jul 12 15:44:52 CDT 2012
It's working now. Thanks again.
Yours sincerely,
TAY wee-beng
On 11/7/2012 11:22 PM, Satish Balay wrote:
> I added the patch to both 3.3 and petsc-dev repos. Hopefully thats easier to use.
> Satish
> On Wed, 11 Jul 2012, Blaise Bourdin wrote:
>> Rectification: clone petsc-3.3, not petsc-dev, of course...
>> B
>>> There is something fishy in your tree or your build: the patch that Satish sent addressed this issue, but it clearly has not been applied to your tree. The patch I had originally sent contained an error. For instance, F90ARRAY4DACCESSFORTRANADDR was replaced by F90ARRAY4dACCESSFORTRANADDR (note the capitalization of the "d"). These are the symbols that are unresolved in your build.
>>> How about starting from a clean state:
>>> - rename your current petsc-dev tree
>>> - clone petsc-dev from the official tree (BTW, do you really need petsc-dev, and not 3.3?)
>>> - apply the patch Satish sent you or, quoting Satich
>>>>> edit src/sys/f90-src/f90_cwrap.c and replace all occurrences of 'F90ARRAY4d' with 'F90ARRAY4D'
>>> - run configure with your favorite options, then make
>>> This should fix your problem.
