[petsc-users] [petsc-dev] second patch for DMDAVecGetArrayF90
Wed Jul 11 13:10:26 CDT 2012
On Wed, 11 Jul 2012, TAY wee-beng wrote:
> I just tried on a different system and the same error occurs. The 1st command
> /patch -Np1 -R < DMDAVecRestoreArrayF90-2.patch
> $ patch -Np1 -R < DMDAVecRestoreArrayF90-2.patch
> (Stripping trailing CRs from patch.)
> patching file src/dm/impls/da/f90-custom/zda1f90.c
> patching file src/sys/f90-src/f90_cwrap.c
> patching file src/sys/f90-src/fsrc/f90_fwrap.F/
> works but the 2nd one doesn't:
> $ patch -Np1  < DMDAVecRestoreArrayF90-2.1.patch
> Hunk #1 FAILED at 175.
> 1 out of 1 hunk FAILED -- saving rejects to file
> src/dm/impls/da/f90-custom/zda1f90.c.rej
> Hunk #1 FAILED at 307.
> Hunk #2 FAILED at 333.
> Hunk #3 FAILED at 436.
> 3 out of 3 hunks FAILED -- saving rejects to file
> src/sys/f90-src/f90_cwrap.c.rej
> Hunk #1 FAILED at 322.
> Hunk #2 FAILED at 426.
> 2 out of 2 hunks FAILED -- saving rejects to file
> src/sys/f90-src/fsrc/f90_fwrap.F.rej/
> It is possible to send me the 3 patch files? Or is there some other ways?
This doesn't make any sense. What petsc-dev do you have? Is it hg
repo? or something else?  What revisions? Are the sources locally
modified?
You can apply DMDAVecRestoreArrayF90-2.patch and then edit
src/sys/f90-src/f90_cwrap.c and replace all occurances of 'F90ARRAY4d'
with 'F90ARRAY4D' in the editor to get the same effect.
Satish
