[petsc-users] [petsc-dev] second patch for DMDAVecGetArrayF90
TAY wee-beng
zonexo at gmail.com
Wed Jul 11 12:39:05 CDT 2012
On 11/7/2012 5:29 PM, Satish Balay wrote:
> Hm - if you have a mercurial clone of petsc-dev - you don't need to
> apply/revert DMDAVecRestoreArrayF90-2.patch. You can just apply
> DMDAVecRestoreArrayF90-2.1.patch.
> But I'm not sure why you are getting errors.
> sbalay at ps3 ~/petsc-dev
> $ hg revert -a
> $ hg st
> $ patch -Np1 < ~/DMDAVecRestoreArrayF90-2.1.patch
> (Stripping trailing CRs from patch.)
> patching file src/dm/impls/da/f90-custom/zda1f90.c
> patching file src/sys/f90-src/f90_cwrap.c
> patching file src/sys/f90-src/fsrc/f90_fwrap.F
> $ hg st
> M src/dm/impls/da/f90-custom/zda1f90.c
> M src/sys/f90-src/f90_cwrap.c
> M src/sys/f90-src/fsrc/f90_fwrap.F
> Satish
I just tried on a different system and the same error occurs. The 1st
command :
/patch -Np1 -R < DMDAVecRestoreArrayF90-2.patch
$ patch -Np1 -R < DMDAVecRestoreArrayF90-2.patch
patching file src/sys/f90-src/fsrc/f90_fwrap.F/
works but the 2nd one doesn't:
$ patch -Np1 < DMDAVecRestoreArrayF90-2.1.patch
Hunk #1 FAILED at 175.
1 out of 1 hunk FAILED -- saving rejects to file src/dm/impls/da/f90-custom/zda1f90.c.rej
Hunk #1 FAILED at 307.
Hunk #2 FAILED at 333.
Hunk #3 FAILED at 436.
3 out of 3 hunks FAILED -- saving rejects to file src/sys/f90-src/f90_cwrap.c.rej
Hunk #1 FAILED at 322.
Hunk #2 FAILED at 426.
2 out of 2 hunks FAILED -- saving rejects to file src/sys/f90-src/fsrc/f90_fwrap.F.rej/
It is possible to send me the 3 patch files? Or is there some other ways?
Thanks
> On Wed, 11 Jul 2012, TAY wee-beng wrote:
>> On 11/7/2012 5:12 PM, Satish Balay wrote:
>>> You would revert the old one - and apply the new one. i.e
>>> patch -Np1 -R< DMDAVecRestoreArrayF90-2.patch
>>> patch -Np1< DMDAVecRestoreArrayF90-2.1.patch
>>> Satish
>> Hi,
>> Just tried but I still get the error:
>> $ !494
>> patch -p1 < DMDAVecRestoreArrayF90-2.patch
>> User at windows-480c6c3 /cygdrive/c/Codes/petsc-dev
>> $ !498
>> $ !500
>>>> On 11/7/2012 3:40 PM, Satish Balay wrote:
>>>>> The second patch has typos. Attaching the modified patch. If it works
>>>>> for
>>>>> you - I'll add it to petsc-3.3/petsc-dev
>>>>> thanks,
>>>>> Satish
>>>> Hi,
>>>> How should I apply the patch? I download a new petsc-dev and used:
>>>> /patch -p1< DMDAVecRestoreArrayF90-2.1.patch
>>>> It says:
>>>> /(Stripping trailing CRs from patch.)
>>>> I also used :
>>>> /patch -p1 DMDAVecRestoreArrayF90-2.patch
>>>> patch -p1 DMDAVecRestoreArrayF90-2.1.patch
>>>> $ patch -p1< DMDAVecRestoreArrayF90-2.patch
>>>> $ patch -p1< DMDAVecRestoreArrayF90-2.1.patch
>>>> Lastly, using patch -p1< DMDAVecRestoreArrayF90.patch gives:
>>>> $ patch -p1< DMDAVecRestoreArrayF90.patch
>>>> Reversed (or previously applied) patch detected! Assume -R? [n] n
>>>> Apply anyway? [n] n
>>>> Skipping patch.
>>>> 4 out of 4 hunks ignored -- saving rejects to file
>>>> src/dm/impls/da/f90-custom/zda1f90.c.rej/
>>>>>> On 6/7/2012 5:48 PM, Barry Smith wrote:
>>>>>>> Blaise,
>>>>>>> Thanks.
>>>>>>> Satish,
>>>>>>> If they look good could you apply them to 3.3 and dev?
>>>>>>> Thanks
>>>>>>> Barry
>>>>>> Hi,
>>>>>> I downloaded petsc-dev a few days ago and applied both patches using
>>>>>> "patch -v
>>>>>> ..." in both linux and windows vs2008
>>>>>> It worked great in linux
>>>>>> However, when I compile and link in vs2008, it gives the error:
>>>>>> 1>Compiling manifest to resources...
>>>>>> 1>Microsoft (R) Windows (R) Resource Compiler Version 6.1.6723.1
>>>>>> 1>Copyright (C) Microsoft Corporation. All rights reserved.
>>>>>> 1>Linking...
>>>>>> 1>libpetsc.lib(f90_cwrap.o) : error LNK2019: unresolved external
>>>>>> symbol
>>>>>> F90ARRAY4dCREATESCALAR referenced in function F90Array4dCreate
>>>>>> symbol
>>>>>> F90ARRAY4dACCESSFORTRANADDR referenced in function F90Array4dAccess
>>>>>> symbol
>>>>>> F90ARRAY4dACCESSINT referenced in function F90Array4dAccess
>>>>>> symbol
>>>>>> F90ARRAY4dACCESSREAL referenced in function F90Array4dAccess
>>>>>> symbol
>>>>>> F90ARRAY4dACCESSSCALAR referenced in function F90Array4dAccess
>>>>>> symbol
>>>>>> F90ARRAY4dDESTROYSCALAR referenced in function F90Array4dDestroy
>>>>>> 1>c:\obj_tmp\ibm2d_high_Re_staggered_old\Debug/ibm2d_high_Re_staggered.exe
>>>>>> fatal error LNK1120: 6 unresolved externals/
>>>>>> I wonder if it's fixed in the new petsc-dev.
>>>>>> Thanks
>>>>>>> On Jul 6, 2012, at 6:30 AM, Blaise Bourdin wrote:
>>>>>>>> Hi,
>>>>>>>> I have added the creation, destruction and accessor functions for
>>>>>>>> 4d
>>>>>>>> vectors in F90. The accessor was missing and needed for
>>>>>>>> DMDAVecGetArrayF90
>>>>>>>> with a 3d DMDA and>1 dof. As far as I can test, ex11f90 in DM
>>>>>>>> should
>>>>>>>> now
>>>>>>>> completely work with the intel compilers.
>>>>>>>> Some of the functions are probably not used (F90Array4dAccessReal,
>>>>>>>> F90Array4dAccessInt, F90Array4dAccessFortranAddr, for instance),
>>>>>>>> but I
>>>>>>>> added them anyway. Let me know if you want me to submit a patch
>>>>>>>> without
>>>>>>>> them.
>>>>>>>> Regards,
>>>>>>>> Blaise
>>>>>>>> <DMDAVecRestoreArrayF90-2.patch>
>>>>>>>> Department of Mathematics and Center for Computation& Technology
>>>>>>>> Louisiana State University, Baton Rouge, LA 70803, USA
>>>>>>>> Tel. +1 (225) 578 1612, Fax +1 (225) 578 4276
>>>>>>>> http://www.math.lsu.edu/~bourdin
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120711/8634863b/attachment.html>
