[petsc-users] [petsc-dev] second patch for DMDAVecGetArrayF90
TAY wee-beng
zonexo at gmail.com
Wed Jul 11 15:44:03 CDT 2012
On 11/7/2012 8:10 PM, Satish Balay wrote:
> On Wed, 11 Jul 2012, TAY wee-beng wrote:
>> I just tried on a different system and the same error occurs. The 1st command
>> /patch -Np1 -R < DMDAVecRestoreArrayF90-2.patch
>> $ patch -Np1 -R < DMDAVecRestoreArrayF90-2.patch
>> (Stripping trailing CRs from patch.)
>> patching file src/dm/impls/da/f90-custom/zda1f90.c
>> patching file src/sys/f90-src/f90_cwrap.c
>> patching file src/sys/f90-src/fsrc/f90_fwrap.F/
>> works but the 2nd one doesn't:
>> $ patch -Np1 < DMDAVecRestoreArrayF90-2.1.patch
>> Hunk #1 FAILED at 175.
>> 1 out of 1 hunk FAILED -- saving rejects to file
>> src/dm/impls/da/f90-custom/zda1f90.c.rej
>> Hunk #1 FAILED at 307.
>> Hunk #2 FAILED at 333.
>> Hunk #3 FAILED at 436.
>> 3 out of 3 hunks FAILED -- saving rejects to file
>> src/sys/f90-src/f90_cwrap.c.rej
>> Hunk #1 FAILED at 322.
>> Hunk #2 FAILED at 426.
>> 2 out of 2 hunks FAILED -- saving rejects to file
>> src/sys/f90-src/fsrc/f90_fwrap.F.rej/
>> It is possible to send me the 3 patch files? Or is there some other ways?
> This doesn't make any sense. What petsc-dev do you have? Is it hg
> repo? or something else? What revisions? Are the sources locally
> modified?
> You can apply DMDAVecRestoreArrayF90-2.patch and then edit
> src/sys/f90-src/f90_cwrap.c and replace all occurances of 'F90ARRAY4d'
> with 'F90ARRAY4D' in the editor to get the same effect.
> Satish
I just tried but the same error occurs:
1>D:\Lib\petsc-3.3-dev_win32_vs2008/include/finclude/ftn-custom/petscdmcomposite.h90(8):
warning #6717: This name has not been given an explicit type. [D1]
1>Linking...
1>libpetsc.lib(f90_cwrap.o) : error LNK2019: unresolved external symbol
F90ARRAY4dCREATESCALAR referenced in function F90Array4dCreate
F90ARRAY4dACCESSFORTRANADDR referenced in function F90Array4dAccess
F90ARRAY4dACCESSINT referenced in function F90Array4dAccess
F90ARRAY4dACCESSREAL referenced in function F90Array4dAccess
F90ARRAY4dACCESSSCALAR referenced in function F90Array4dAccess
F90ARRAY4dDESTROYSCALAR referenced in function F90Array4dDestroy
1>c:\obj_tmp\dm_test2d\Debug/dm_test2d.exe : fatal error LNK1120: 6
unresolved externals
1>
1>Build log written to "file://c:\obj_tmp\dm_test2d\Debug\BuildLog.htm"/
Any other solutions?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120711/54007e5e/attachment.html>
