[petsc-users] [petsc-dev] second patch for DMDAVecGetArrayF90
Wed Jul 11 10:29:24 CDT 2012
Hm - if you have a mercurial clone of petsc-dev - you don't need to
apply/revert DMDAVecRestoreArrayF90-2.patch. You can just apply
DMDAVecRestoreArrayF90-2.1.patch.
But I'm not sure why you are getting errors.
sbalay at ps3 ~/petsc-dev
$ hg revert -a
$ hg st
$ patch -Np1 < ~/DMDAVecRestoreArrayF90-2.1.patch
(Stripping trailing CRs from patch.)
patching file src/dm/impls/da/f90-custom/zda1f90.c
patching file src/sys/f90-src/f90_cwrap.c
patching file src/sys/f90-src/fsrc/f90_fwrap.F
$ hg st
M src/dm/impls/da/f90-custom/zda1f90.c
M src/sys/f90-src/f90_cwrap.c
M src/sys/f90-src/fsrc/f90_fwrap.F
Satish
On Wed, 11 Jul 2012, TAY wee-beng wrote:
> On 11/7/2012 5:12 PM, Satish Balay wrote:
> > You would revert the old one - and apply the new one. i.e
> > patch -Np1 -R<  DMDAVecRestoreArrayF90-2.patch
> > patch -Np1<  DMDAVecRestoreArrayF90-2.1.patch
> > Satish
> Hi,
> Just tried but I still get the error:
> $ !494
> patch -p1 < DMDAVecRestoreArrayF90-2.patch
> User at windows-480c6c3 /cygdrive/c/Codes/petsc-dev
> $ !498
> patch -Np1 -R < DMDAVecRestoreArrayF90-2.patch
> $ !500
> patch -Np1 < DMDAVecRestoreArrayF90-2.1.patch
> Hunk #1 FAILED at 175.
> 1 out of 1 hunk FAILED -- saving rejects to file
> src/dm/impls/da/f90-custom/zda1f90.c.rej
> Hunk #1 FAILED at 307.
> Hunk #2 FAILED at 333.
> Hunk #3 FAILED at 436.
> 3 out of 3 hunks FAILED -- saving rejects to file
> src/sys/f90-src/f90_cwrap.c.rej
> Hunk #1 FAILED at 322.
> Hunk #2 FAILED at 426.
> 2 out of 2 hunks FAILED -- saving rejects to file
> src/sys/f90-src/fsrc/f90_fwrap.F.rej
> > > On 11/7/2012 3:40 PM, Satish Balay wrote:
> > > > The second patch has typos. Attaching the modified patch. If it works
> > > > for
> > > > you - I'll add it to petsc-3.3/petsc-dev
> > > > thanks,
> > > > Satish
> > > Hi,
> > > How should I apply the patch? I download a new petsc-dev and used:
> > > /patch -p1<  DMDAVecRestoreArrayF90-2.1.patch
> > > It says:
> > > /(Stripping trailing CRs from patch.)
> > > src/sys/f90-src/fsrc/f90_fwrap.F.rej/
> > > I also used :
> > > /patch -p1 DMDAVecRestoreArrayF90-2.patch
> > > patch -p1 DMDAVecRestoreArrayF90-2.1.patch
> > > $ patch -p1<  DMDAVecRestoreArrayF90-2.patch
> > > $ patch -p1<  DMDAVecRestoreArrayF90-2.1.patch
> > > Lastly, using patch -p1<  DMDAVecRestoreArrayF90.patch gives:
> > > $ patch -p1<  DMDAVecRestoreArrayF90.patch
> > > Reversed (or previously applied) patch detected!  Assume -R? [n] n
> > > Apply anyway? [n] n
> > > Skipping patch.
> > > 4 out of 4 hunks ignored -- saving rejects to file
> > > src/dm/impls/da/f90-custom/zda1f90.c.rej/
> > > > > On 6/7/2012 5:48 PM, Barry Smith wrote:
> > > > > >       Blaise,
> > > > > >          Thanks.
> > > > > >       Satish,
> > > > > >          If they look good could you apply them to 3.3 and dev?
> > > > > >         Thanks
> > > > > >          Barry
> > > > > Hi,
> > > > > I downloaded petsc-dev a few days ago and applied both patches using
> > > > > "patch -v
> > > > > ..." in both linux and windows vs2008
> > > > > It worked great in linux
> > > > > However, when I compile and link in vs2008, it gives the error:
> > > > > 1>Compiling manifest to resources...
> > > > > 1>Microsoft (R) Windows (R) Resource Compiler Version 6.1.6723.1
> > > > > 1>Copyright (C) Microsoft Corporation.  All rights reserved.
> > > > > 1>Linking...
> > > > > 1>libpetsc.lib(f90_cwrap.o) : error LNK2019: unresolved external
> > > > > symbol
> > > > > F90ARRAY4dCREATESCALAR referenced in function F90Array4dCreate
> > > > > symbol
> > > > > F90ARRAY4dACCESSFORTRANADDR referenced in function F90Array4dAccess
> > > > > symbol
> > > > > F90ARRAY4dACCESSINT referenced in function F90Array4dAccess
> > > > > symbol
> > > > > F90ARRAY4dACCESSREAL referenced in function F90Array4dAccess
> > > > > symbol
> > > > > F90ARRAY4dACCESSSCALAR referenced in function F90Array4dAccess
> > > > > symbol
> > > > > F90ARRAY4dDESTROYSCALAR referenced in function F90Array4dDestroy
> > > > > 1>c:\obj_tmp\ibm2d_high_Re_staggered_old\Debug/ibm2d_high_Re_staggered.exe
> > > > > fatal error LNK1120: 6 unresolved externals/
> > > > > I wonder if it's fixed in the new petsc-dev.
> > > > > Thanks
> > > > > > On Jul 6, 2012, at 6:30 AM, Blaise Bourdin wrote:
> > > > > > > Hi,
> > > > > > > I have added the creation, destruction and accessor functions for
> > > > > > > 4d
> > > > > > > vectors in F90. The accessor was missing and needed for
> > > > > > > DMDAVecGetArrayF90
> > > > > > > with a 3d DMDA and>1 dof. As far as I can test, ex11f90 in DM
> > > > > > > should
> > > > > > > now
> > > > > > > completely work with the intel compilers.
> > > > > > > Some of the functions are probably not used (F90Array4dAccessReal,
> > > > > > > F90Array4dAccessInt, F90Array4dAccessFortranAddr, for instance),
> > > > > > > but I
> > > > > > > added them anyway. Let me know if you want me to submit a patch
> > > > > > > without
> > > > > > > them.
> > > > > > > Regards,
> > > > > > > Blaise
> > > > > > > <DMDAVecRestoreArrayF90-2.patch>
> > > > > > > Department of Mathematics and Center for Computation&   Technology
> > > > > > > Louisiana State University, Baton Rouge, LA 70803, USA
> > > > > > > Tel. +1 (225) 578 1612, Fax  +1 (225) 578 4276
> > > > > > > http://www.math.lsu.edu/~bourdin
