[petsc-users] [petsc-dev] second patch for DMDAVecGetArrayF90
TAY wee-beng
zonexo at gmail.com
Wed Jul 11 10:21:46 CDT 2012
On 11/7/2012 5:12 PM, Satish Balay wrote:
> You would revert the old one - and apply the new one. i.e
> patch -Np1 -R< DMDAVecRestoreArrayF90-2.patch
> patch -Np1< DMDAVecRestoreArrayF90-2.1.patch
> Satish
Just tried but I still get the error:
$ !494
patch -p1 < DMDAVecRestoreArrayF90-2.patch
(Stripping trailing CRs from patch.)
patching file src/dm/impls/da/f90-custom/zda1f90.c
patching file src/sys/f90-src/f90_cwrap.c
patching file src/sys/f90-src/fsrc/f90_fwrap.F
User at windows-480c6c3 /cygdrive/c/Codes/petsc-dev
$ !498
patch -Np1 -R < DMDAVecRestoreArrayF90-2.patch
$ !500
patch -Np1 < DMDAVecRestoreArrayF90-2.1.patch
Hunk #1 FAILED at 175.
1 out of 1 hunk FAILED -- saving rejects to file
src/dm/impls/da/f90-custom/zda1f90.c.rej
Hunk #1 FAILED at 307.
Hunk #2 FAILED at 333.
Hunk #3 FAILED at 436.
3 out of 3 hunks FAILED -- saving rejects to file
src/sys/f90-src/f90_cwrap.c.rej
Hunk #1 FAILED at 322.
Hunk #2 FAILED at 426.
2 out of 2 hunks FAILED -- saving rejects to file
src/sys/f90-src/fsrc/f90_fwrap.F.rej
> On Wed, 11 Jul 2012, TAY wee-beng wrote:
>> On 11/7/2012 3:40 PM, Satish Balay wrote:
>>> The second patch has typos. Attaching the modified patch. If it works for
>>> you - I'll add it to petsc-3.3/petsc-dev
>>> thanks,
>>> Satish
>> Hi,
>> How should I apply the patch? I download a new petsc-dev and used:
>> /patch -p1< DMDAVecRestoreArrayF90-2.1.patch
>> It says:
>> /(Stripping trailing CRs from patch.)
>> src/sys/f90-src/fsrc/f90_fwrap.F.rej/
>> I also used :
>> /patch -p1 DMDAVecRestoreArrayF90-2.patch
>> patch -p1 DMDAVecRestoreArrayF90-2.1.patch
>> $ patch -p1< DMDAVecRestoreArrayF90-2.patch
>> $ patch -p1< DMDAVecRestoreArrayF90-2.1.patch
>> Lastly, using patch -p1< DMDAVecRestoreArrayF90.patch gives:
>> $ patch -p1< DMDAVecRestoreArrayF90.patch
>> Reversed (or previously applied) patch detected! Assume -R? [n] n
>> Apply anyway? [n] n
>> Skipping patch.
>> 4 out of 4 hunks ignored -- saving rejects to file
>> src/dm/impls/da/f90-custom/zda1f90.c.rej/
>>>> On 6/7/2012 5:48 PM, Barry Smith wrote:
>>>>> Blaise,
>>>>> Thanks.
>>>>> Satish,
>>>>> If they look good could you apply them to 3.3 and dev?
>>>>> Thanks
>>>>> Barry
>>>> Hi,
>>>> I downloaded petsc-dev a few days ago and applied both patches using
>>>> "patch -v
>>>> ..." in both linux and windows vs2008
>>>> It worked great in linux
>>>> However, when I compile and link in vs2008, it gives the error:
>>>> 1>Compiling manifest to resources...
>>>> 1>Microsoft (R) Windows (R) Resource Compiler Version 6.1.6723.1
>>>> 1>Copyright (C) Microsoft Corporation. All rights reserved.
>>>> 1>Linking...
>>>> 1>libpetsc.lib(f90_cwrap.o) : error LNK2019: unresolved external symbol
>>>> F90ARRAY4dCREATESCALAR referenced in function F90Array4dCreate
>>>> F90ARRAY4dACCESSFORTRANADDR referenced in function F90Array4dAccess
>>>> F90ARRAY4dACCESSINT referenced in function F90Array4dAccess
>>>> F90ARRAY4dACCESSREAL referenced in function F90Array4dAccess
>>>> F90ARRAY4dACCESSSCALAR referenced in function F90Array4dAccess
>>>> F90ARRAY4dDESTROYSCALAR referenced in function F90Array4dDestroy
>>>> 1>c:\obj_tmp\ibm2d_high_Re_staggered_old\Debug/ibm2d_high_Re_staggered.exe
>>>> fatal error LNK1120: 6 unresolved externals/
>>>> I wonder if it's fixed in the new petsc-dev.
>>>> Thanks
>>>>> On Jul 6, 2012, at 6:30 AM, Blaise Bourdin wrote:
>>>>>> Hi,
>>>>>> I have added the creation, destruction and accessor functions for 4d
>>>>>> vectors in F90. The accessor was missing and needed for
>>>>>> DMDAVecGetArrayF90
>>>>>> with a 3d DMDA and>1 dof. As far as I can test, ex11f90 in DM should
>>>>>> now
>>>>>> completely work with the intel compilers.
>>>>>> Some of the functions are probably not used (F90Array4dAccessReal,
>>>>>> F90Array4dAccessInt, F90Array4dAccessFortranAddr, for instance), but I
>>>>>> added them anyway. Let me know if you want me to submit a patch
>>>>>> without
>>>>>> them.
>>>>>> Regards,
>>>>>> Blaise
>>>>>> <DMDAVecRestoreArrayF90-2.patch>
>>>>>> Department of Mathematics and Center for Computation& Technology
>>>>>> Louisiana State University, Baton Rouge, LA 70803, USA
>>>>>> Tel. +1 (225) 578 1612, Fax +1 (225) 578 4276
>>>>>> http://www.math.lsu.edu/~bourdin
