[petsc-users] [petsc-dev] second patch for DMDAVecGetArrayF90
Satish Balay
balay at mcs.anl.gov
Wed Jul 11 08:40:10 CDT 2012
The second patch has typos. Attaching the modified patch. If it works for
you - I'll add it to petsc-3.3/petsc-dev
thanks,
Satish
On Wed, 11 Jul 2012, TAY wee-beng wrote:
> On 6/7/2012 5:48 PM, Barry Smith wrote:
> > Blaise,
> > Thanks.
> > Satish,
> > If they look good could you apply them to 3.3 and dev?
> > Thanks
> > Barry
> Hi,
> I downloaded petsc-dev a few days ago and applied both patches using "patch -v
> ..." in both linux and windows vs2008
> It worked great in linux
> However, when I compile and link in vs2008, it gives the error:
> 1>Compiling manifest to resources...
> 1>Microsoft (R) Windows (R) Resource Compiler Version 6.1.6723.1
> 1>Copyright (C) Microsoft Corporation. All rights reserved.
> 1>Linking...
> 1>libpetsc.lib(f90_cwrap.o) : error LNK2019: unresolved external symbol
> F90ARRAY4dCREATESCALAR referenced in function F90Array4dCreate
> F90ARRAY4dACCESSFORTRANADDR referenced in function F90Array4dAccess
> F90ARRAY4dACCESSINT referenced in function F90Array4dAccess
> F90ARRAY4dACCESSREAL referenced in function F90Array4dAccess
> F90ARRAY4dACCESSSCALAR referenced in function F90Array4dAccess
> F90ARRAY4dDESTROYSCALAR referenced in function F90Array4dDestroy
> 1>c:\obj_tmp\ibm2d_high_Re_staggered_old\Debug/ibm2d_high_Re_staggered.exe :
> fatal error LNK1120: 6 unresolved externals/
> I wonder if it's fixed in the new petsc-dev.
> Thanks
> > On Jul 6, 2012, at 6:30 AM, Blaise Bourdin wrote:
> > > Hi,
> > > I have added the creation, destruction and accessor functions for 4d
> > > vectors in F90. The accessor was missing and needed for DMDAVecGetArrayF90
> > > with a 3d DMDA and >1 dof. As far as I can test, ex11f90 in DM should now
> > > completely work with the intel compilers.
> > > Some of the functions are probably not used (F90Array4dAccessReal,
> > > F90Array4dAccessInt, F90Array4dAccessFortranAddr, for instance), but I
> > > added them anyway. Let me know if you want me to submit a patch without
> > > them.
> > > Regards,
> > > Blaise
> > > <DMDAVecRestoreArrayF90-2.patch>
> > > Department of Mathematics and Center for Computation & Technology
> > > Louisiana State University, Baton Rouge, LA 70803, USA
> > > Tel. +1 (225) 578 1612, Fax +1 (225) 578 4276
> > > http://www.math.lsu.edu/~bourdin
diff -r c449016b5325 src/dm/impls/da/f90-custom/zda1f90.c
--- a/src/dm/impls/da/f90-custom/zda1f90.c Tue Jul 03 13:22:19 2012 -0500
+++ b/src/dm/impls/da/f90-custom/zda1f90.c Fri Jul 06 15:15:48 2012 +0400
@@ -175,9 +175,7 @@ void PETSC_STDCALL dmdavecrestorearrayf9
F90Array4dAccess is not implemented, so the following call would fail
*ierr = F90Array4dAccess(a,PETSC_SCALAR,(void**)&fa PETSC_F90_2PTR_PARAM(ptrd));
*ierr = VecRestoreArray(*v,&fa);if (*ierr) return;
*ierr = F90Array4dDestroy(&a,PETSC_SCALAR PETSC_F90_2PTR_PARAM(ptrd));
diff -r c449016b5325 src/sys/f90-src/f90_cwrap.c
--- a/src/sys/f90-src/f90_cwrap.c Tue Jul 03 13:22:19 2012 -0500
+++ b/src/sys/f90-src/f90_cwrap.c Fri Jul 06 15:15:48 2012 +0400
@@ -307,17 +307,46 @@ PetscErrorCode F90Array3dDestroy(F90Arr
#if defined(PETSC_HAVE_FORTRAN_CAPS)
-#define f90array4dcreatescalar_ F90ARRAY4DCREATESCALAR
-#define f90array4ddestroyscalar_ F90ARRAY4DDESTROYSCALAR
+#define f90array4dcreatescalar_ F90ARRAY4DCREATESCALAR
+#define f90array4daccessscalar_ F90ARRAY4DACCESSSCALAR
+#define f90array4ddestroyscalar_ F90ARRAY4DDESTROYSCALAR
+#define f90array4dcreatereal_ F90ARRAY4DCREATEREAL
+#define f90array4daccessreal_ F90ARRAY4DACCESSREAL
+#define f90array4ddestroyreal_ F90ARRAY4DDESTROYREAL
+#define f90array4dcreateint_ F90ARRAY4DCREATEINT
+#define f90array4daccessint_ F90ARRAY4DACCESSINT
+#define f90array4ddestroyint_ F90ARRAY4DDESTROYINT
+#define f90array4dcreatefortranaddr_ F90ARRAY4DCREATEFORTRANADDR
+#define f90array4daccessfortranaddr_ F90ARRAY4DACCESSFORTRANADDR
+#define f90array4ddestroyfortranaddr_ F90ARRAY4DDESTROYFORTRANADDR
#elif !defined(PETSC_HAVE_FORTRAN_UNDERSCORE)
#define f90array4dcreatescalar_ f90array4dcreatescalar
+#define f90array4daccessscalar_ f90array4daccessscalar
#define f90array4ddestroyscalar_ f90array4ddestroyscalar
+#define f90array4dcreatereal_ f90array4dcreatereal
+#define f90array4daccessreal_ f90array4daccessreal
+#define f90array4ddestroyreal_ f90array4ddestroyreal
+#define f90array4dcreateint_ f90array4dcreateint
+#define f90array4daccessint_ f90array4daccessint
+#define f90array4ddestroyint_ f90array4ddestroyint
+#define f90array4dcreatefortranaddr_ f90array4dcreatefortranaddr
+#define f90array4daccessfortranaddr_ f90array4daccessfortranaddr
+#define f90array4ddestroyfortranaddr_ f90array4ddestroyfortranaddr
#endif
PETSC_EXTERN_C void PETSC_STDCALL f90array4dcreatescalar_(void *,PetscInt *,PetscInt *,PetscInt *,PetscInt *,PetscInt *,PetscInt *,PetscInt*,PetscInt*,F90Array4d * PETSC_F90_2PTR_PROTO_NOVAR);
+PETSC_EXTERN_C void PETSC_STDCALL f90array4daccessscalar_(F90Array4d*,void** PETSC_F90_2PTR_PROTO_NOVAR);
PETSC_EXTERN_C void PETSC_STDCALL f90array4ddestroyscalar_(F90Array4d *ptr PETSC_F90_2PTR_PROTO_NOVAR);
+PETSC_EXTERN_C void PETSC_STDCALL f90array4dcreatereal_(void *,PetscInt *,PetscInt *,PetscInt *,PetscInt *,PetscInt *,PetscInt *,PetscInt*,PetscInt*,F90Array4d * PETSC_F90_2PTR_PROTO_NOVAR);
+PETSC_EXTERN_C void PETSC_STDCALL f90array4daccessreal_(F90Array4d*,void** PETSC_F90_2PTR_PROTO_NOVAR);
+PETSC_EXTERN_C void PETSC_STDCALL f90array4ddestroyreal_(F90Array4d *ptr PETSC_F90_2PTR_PROTO_NOVAR);
+PETSC_EXTERN_C void PETSC_STDCALL f90array4dcreateint_(void *,PetscInt *,PetscInt *,PetscInt *,PetscInt *,PetscInt *,PetscInt *,PetscInt*,PetscInt*,F90Array4d * PETSC_F90_2PTR_PROTO_NOVAR);
+PETSC_EXTERN_C void PETSC_STDCALL f90array4daccessint_(F90Array4d*,void** PETSC_F90_2PTR_PROTO_NOVAR);
+PETSC_EXTERN_C void PETSC_STDCALL f90array4ddestroyint_(F90Array4d *ptr PETSC_F90_2PTR_PROTO_NOVAR);
+PETSC_EXTERN_C void PETSC_STDCALL f90array4dcreatefortranaddr_(void *,PetscInt *,PetscInt *,PetscInt *,PetscInt *,PetscInt *,PetscInt *,PetscInt*,PetscInt*,F90Array4d * PETSC_F90_2PTR_PROTO_NOVAR);
+PETSC_EXTERN_C void PETSC_STDCALL f90array4daccessfortranaddr_(F90Array4d*,void** PETSC_F90_2PTR_PROTO_NOVAR);
+PETSC_EXTERN_C void PETSC_STDCALL f90array4ddestroyfortranaddr_(F90Array4d *ptr PETSC_F90_2PTR_PROTO_NOVAR);
#undef __FUNCT__
#define __FUNCT__ "F90Array4dCreate"
@@ -333,6 +362,25 @@ PetscErrorCode F90Array4dCreate(void *ar
#undef __FUNCT__
+#define __FUNCT__ "F90Array4dAccess"
+PetscErrorCode F90Array4dAccess(F90Array4d *ptr,PetscDataType type,void **array PETSC_F90_2PTR_PROTO(ptrd))
+ PetscFunctionBegin;
+ if (type == PETSC_SCALAR) {
+ f90array4daccessscalar_(ptr,array PETSC_F90_2PTR_PARAM(ptrd));
+ } else if (type == PETSC_REAL) {
+ f90array4daccessreal_(ptr,array PETSC_F90_2PTR_PARAM(ptrd));
+ } else if (type == PETSC_INT) {
+ f90array4daccessint_(ptr,array PETSC_F90_2PTR_PARAM(ptrd));
+ } else if (type == PETSC_FORTRANADDR) {
+ f90array4daccessfortranaddr_(ptr,array PETSC_F90_2PTR_PARAM(ptrd));
+ } else {
+ SETERRQ1(PETSC_COMM_SELF,PETSC_ERR_SUP,"unsupported PetscDataType: %d",(PetscInt)type);
+ PetscFunctionReturn(0);
+#undef __FUNCT__
#define __FUNCT__ "F90Array4dDestroy"
PetscErrorCode F90Array4dDestroy(F90Array4d *ptr,PetscDataType type PETSC_F90_2PTR_PROTO(ptrd))
@@ -436,3 +484,31 @@ PETSC_EXTERN_C void PETSC_STDCALL f90arr
+#if defined(PETSC_HAVE_FORTRAN_CAPS)
+#define f90array4dgetaddrscalar_ F90ARRAY4DGETADDRSCALAR
+#define f90array4dgetaddrreal_ F90ARRAY4DGETADDRREAL
+#define f90array4dgetaddrint_ F90ARRAY4DGETADDRINT
+#define f90array4dgetaddrfortranaddr_ F90ARRAY4DGETADDRFORTRANADDR
+#elif !defined(PETSC_HAVE_FORTRAN_UNDERSCORE)
+#define f90array4dgetaddrscalar_ f90array4dgetaddrscalar
+#define f90array4dgetaddrreal_ f90array4dgetaddrreal
+#define f90array4dgetaddrint_ f90array4dgetaddrint
+#define f90array4dgetaddrfortranaddr_ f90array4dgetaddrfortranaddr
+#endif
+PETSC_EXTERN_C void PETSC_STDCALL f90array4dgetaddrscalar_(void *array, PetscFortranAddr *address)
+ *address = (PetscFortranAddr)array;
+PETSC_EXTERN_C void PETSC_STDCALL f90array4dgetaddrreal_(void *array, PetscFortranAddr *address)
+PETSC_EXTERN_C void PETSC_STDCALL f90array4dgetaddrint_(void *array, PetscFortranAddr *address)
+PETSC_EXTERN_C void PETSC_STDCALL f90array4dgetaddrfortranaddr_(void *array, PetscFortranAddr *address)
diff -r c449016b5325 src/sys/f90-src/fsrc/f90_fwrap.F
--- a/src/sys/f90-src/fsrc/f90_fwrap.F Tue Jul 03 13:22:19 2012 -0500
+++ b/src/sys/f90-src/fsrc/f90_fwrap.F Fri Jul 06 15:15:48 2012 +0400
@@ -322,23 +322,6 @@
end subroutine
- subroutine F90Array4dCreateScalar(array,start1,len1, &
- & start2,len2,start3,len3,start4,len4,ptr)
- implicit none
-#include <finclude/petscsys.h>
- PetscInt start1,len1
- PetscInt start2,len2
- PetscInt start3,len3
- PetscInt start4,len4
- PetscScalar, target :: &
- & array(start1:start1+len1-1,start2:start2+len2-1, &
- & start3:start3+len3-1,start4:start4+len4-1)
- PetscScalar, pointer :: ptr(:,:,:,:)
- ptr => array
- end subroutine
subroutine F90Array3dAccessScalar(ptr,address)
implicit none
@@ -426,10 +409,158 @@
end subroutine
+ subroutine F90Array4dCreateScalar(array,start1,len1, &
+ & start2,len2,start3,len3,start4,len4,ptr)
+ implicit none
+#include <finclude/petscsys.h>
+ PetscInt start1,len1
+ PetscInt start2,len2
+ PetscInt start3,len3
+ PetscInt start4,len4
+ PetscScalar, target :: &
+ & array(start1:start1+len1-1,start2:start2+len2-1, &
+ & start3:start3+len3-1,start4:start4+len4-1)
+ PetscScalar, pointer :: ptr(:,:,:,:)
+ ptr => array
+ end subroutine
+ subroutine F90Array4dCreateReal(array,start1,len1, &
+ implicit none
+ PetscReal, target :: &
+ PetscReal, pointer :: ptr(:,:,:,:)
+ ptr => array
+ end subroutine
+ subroutine F90Array4dCreateInt(array,start1,len1, &
+ implicit none
+ PetscInt, target :: &
+ PetscInt, pointer :: ptr(:,:,:,:)
+ ptr => array
+ end subroutine
+ subroutine F90Array4dCreateFortranAddr(array,start1,len1, &
+ implicit none
+ PetscFortranAddr, target :: &
+ PetscFortranAddr, pointer :: ptr(:,:,:,:)
+ ptr => array
+ end subroutine
+ subroutine F90Array4dAccessScalar(ptr,address)
+ implicit none
+ PetscFortranAddr address
+ PetscInt start1,start2,start3,start4
+ start1 = lbound(ptr,1)
+ start2 = lbound(ptr,2)
+ start3 = lbound(ptr,3)
+ start4 = lbound(ptr,4)
+ call F90Array4dGetAddrScalar(ptr(start1,start2,start3,start4), &
+ & address)
+ end subroutine
+ subroutine F90Array4dAccessReal(ptr,address)
+ implicit none
+ call F90Array4dGetAddrReal(ptr(start1,start2,start3,start4), &
+ & address)
+ end subroutine
+ subroutine F90Array4dAccessInt(ptr,address)
+ implicit none
+ call F90Array4dGetAddrInt(ptr(start1,start2,start3,start4), &
+ & address)
+ end subroutine
+ subroutine F90Array4dAccessFortranAddr(ptr,address)
+ implicit none
+ PetscFortranAddr start1,start2,start3,start4
+ call F90Array4dGetAddrFortranAddr(ptr(start1,start2,start3, &
+ & start4),address)
+ end subroutine
subroutine F90Array4dDestroyScalar(ptr)
implicit none
- PetscScalar, pointer :: ptr(:,:,:)
+ nullify(ptr)
+ end subroutine
+ subroutine F90Array4dDestroyReal(ptr)
+ implicit none
+ nullify(ptr)
+ end subroutine
+ subroutine F90Array4dDestroyInt(ptr)
+ implicit none
+ nullify(ptr)
+ end subroutine
+ subroutine F90Array4dDestroyFortranAddr(ptr)
+ implicit none
nullify(ptr)
end subroutine
