[petsc-users] [petsc-dev] second patch for DMDAVecGetArrayF90
TAY wee-beng
zonexo at gmail.com
Wed Jul 11 10:05:58 CDT 2012
On 11/7/2012 3:40 PM, Satish Balay wrote:
> The second patch has typos. Attaching the modified patch. If it works for
> you - I'll add it to petsc-3.3/petsc-dev
> thanks,
> Satish
How should I apply the patch? I download a new petsc-dev and used:
/patch -p1 < DMDAVecRestoreArrayF90-2.1.patch
It says:
/(Stripping trailing CRs from patch.)
patching file src/dm/impls/da/f90-custom/zda1f90.c
Hunk #1 FAILED at 175.
1 out of 1 hunk FAILED -- saving rejects to file
src/dm/impls/da/f90-custom/zda1f90.c.rej
patching file src/sys/f90-src/f90_cwrap.c
Hunk #1 FAILED at 307.
Hunk #2 FAILED at 333.
Hunk #3 FAILED at 436.
3 out of 3 hunks FAILED -- saving rejects to file
src/sys/f90-src/f90_cwrap.c.rej
patching file src/sys/f90-src/fsrc/f90_fwrap.F
Hunk #1 FAILED at 322.
Hunk #2 FAILED at 426.
2 out of 2 hunks FAILED -- saving rejects to file
src/sys/f90-src/fsrc/f90_fwrap.F.rej/
I also used :
/patch -p1 DMDAVecRestoreArrayF90-2.patch
patch -p1 DMDAVecRestoreArrayF90-2.1.patch
$ patch -p1 < DMDAVecRestoreArrayF90-2.patch
$ patch -p1 < DMDAVecRestoreArrayF90-2.1.patch
Lastly, using patch -p1 < DMDAVecRestoreArrayF90.patch gives:
$ patch -p1 < DMDAVecRestoreArrayF90.patch
Reversed (or previously applied) patch detected! Assume -R? [n] n
Apply anyway? [n] n
Skipping patch.
4 out of 4 hunks ignored -- saving rejects to file
src/dm/impls/da/f90-custom/zda1f90.c.rej/
> On Wed, 11 Jul 2012, TAY wee-beng wrote:
>> On 6/7/2012 5:48 PM, Barry Smith wrote:
>>> Blaise,
>>> Thanks.
>>> Satish,
>>> If they look good could you apply them to 3.3 and dev?
>>> Thanks
>>> Barry
>> Hi,
>> I downloaded petsc-dev a few days ago and applied both patches using "patch -v
>> ..." in both linux and windows vs2008
>> It worked great in linux
>> However, when I compile and link in vs2008, it gives the error:
>> 1>Compiling manifest to resources...
>> 1>Microsoft (R) Windows (R) Resource Compiler Version 6.1.6723.1
>> 1>Copyright (C) Microsoft Corporation. All rights reserved.
>> 1>Linking...
>> 1>libpetsc.lib(f90_cwrap.o) : error LNK2019: unresolved external symbol
>> F90ARRAY4dCREATESCALAR referenced in function F90Array4dCreate
>> F90ARRAY4dACCESSFORTRANADDR referenced in function F90Array4dAccess
>> F90ARRAY4dACCESSINT referenced in function F90Array4dAccess
>> F90ARRAY4dACCESSREAL referenced in function F90Array4dAccess
>> F90ARRAY4dACCESSSCALAR referenced in function F90Array4dAccess
>> F90ARRAY4dDESTROYSCALAR referenced in function F90Array4dDestroy
>> 1>c:\obj_tmp\ibm2d_high_Re_staggered_old\Debug/ibm2d_high_Re_staggered.exe :
>> fatal error LNK1120: 6 unresolved externals/
>> I wonder if it's fixed in the new petsc-dev.
>> Thanks
>>> On Jul 6, 2012, at 6:30 AM, Blaise Bourdin wrote:
>>>> Hi,
>>>> I have added the creation, destruction and accessor functions for 4d
>>>> vectors in F90. The accessor was missing and needed for DMDAVecGetArrayF90
>>>> with a 3d DMDA and>1 dof. As far as I can test, ex11f90 in DM should now
>>>> completely work with the intel compilers.
>>>> Some of the functions are probably not used (F90Array4dAccessReal,
>>>> F90Array4dAccessInt, F90Array4dAccessFortranAddr, for instance), but I
>>>> added them anyway. Let me know if you want me to submit a patch without
>>>> them.
>>>> Regards,
>>>> Blaise
>>>> <DMDAVecRestoreArrayF90-2.patch>
>>>> Department of Mathematics and Center for Computation& Technology
>>>> Louisiana State University, Baton Rouge, LA 70803, USA
>>>> Tel. +1 (225) 578 1612, Fax +1 (225) 578 4276
>>>> http://www.math.lsu.edu/~bourdin
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120711/e0b3ff2c/attachment-0001.html>
