[petsc-users] [petsc-dev] second patch for DMDAVecGetArrayF90
    TAY wee-beng
    zonexo at gmail.com
    Wed Jul 11 04:13:02 CDT 2012
On 6/7/2012 5:48 PM, Barry Smith wrote:
>     Blaise,
>        Thanks.
>     Satish,
>        If they look good could you apply them to 3.3 and dev?
>       Thanks
>        Barry
I downloaded petsc-dev a few days ago and applied both patches using
"patch -v ..." in both linux and windows vs2008
It worked great in linux
However, when I compile and link in vs2008, it gives the error:
1>Compiling manifest to resources...
1>Microsoft (R) Windows (R) Resource Compiler Version 6.1.6723.1
1>Copyright (C) Microsoft Corporation.  All rights reserved.
1>Linking...
1>libpetsc.lib(f90_cwrap.o) : error LNK2019: unresolved external symbol
F90ARRAY4dCREATESCALAR referenced in function F90Array4dCreate
F90ARRAY4dACCESSFORTRANADDR referenced in function F90Array4dAccess
F90ARRAY4dACCESSINT referenced in function F90Array4dAccess
F90ARRAY4dACCESSREAL referenced in function F90Array4dAccess
F90ARRAY4dACCESSSCALAR referenced in function F90Array4dAccess
F90ARRAY4dDESTROYSCALAR referenced in function F90Array4dDestroy
1>c:\obj_tmp\ibm2d_high_Re_staggered_old\Debug/ibm2d_high_Re_staggered.exe
: fatal error LNK1120: 6 unresolved externals/
I wonder if it's fixed in the new petsc-dev.
Thanks
> On Jul 6, 2012, at 6:30 AM, Blaise Bourdin wrote:
>> Hi,
>> I have added the creation, destruction and accessor functions for 4d vectors in F90. The accessor was missing and needed for DMDAVecGetArrayF90 with a 3d DMDA and >1 dof. As far as I can test, ex11f90 in DM should now completely work with the intel compilers.
>> Some of the functions are probably not used (F90Array4dAccessReal, F90Array4dAccessInt, F90Array4dAccessFortranAddr, for instance), but I added them anyway. Let me know if you want me to submit a patch without them.
>> Regards,
>> Blaise
>> <DMDAVecRestoreArrayF90-2.patch>
>> Department of Mathematics and Center for Computation & Technology
>> Louisiana State University, Baton Rouge, LA 70803, USA
>> Tel. +1 (225) 578 1612, Fax  +1 (225) 578 4276 http://www.math.lsu.edu/~bourdin
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120711/2b38f398/attachment.html>
