[petsc-users] Matrix format mpiaij does not have a built-in PETSc XXX!
Tue Feb 28 10:41:35 CST 2012
On Tue, Feb 28, 2012 at 3:19 AM, Bojan Niceno <bojan.niceno at psi.ch> wrote:
>  On 2/28/2012 10:04 AM, Aron Roland wrote:
> Hi Bojan,
> the PCILU package does not work with mpiaij matrices, same as PCICC.
> Basically only PCSOR works.
> Auch :-(  When I saw your reply, I was hoping you will say: "I've found a
> resolution in the meantime", but you only confirmed my fears.
Look, I already replied to this, and now Jed had to reply again. If you are
not going to read our mail, why mail the list?
   Matt
>     Cheers
>     Bojan
> You can install the hypre package then you can use the hypre solvers that
> also include an ILU PC names BILUT, however I did not had any success to
> achieve convergence, even if my SPARSKIT ILU-BCGSTAB converges very well.
> Hope this helped.
> Cheers
> Aron
> On 02/28/2012 08:47 AM, Bojan Niceno wrote:
> Dear all,
> Max may be correct, but I encounter the same problem as Aron.  Neither
> PCILU nor PCICC work in parallel for me.  Here is the message I get:
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: No support for this operation for this object type!
> [0]PETSC ERROR: Matrix format mpiaij does not have a built-in PETSc ICC!
> [0]PETSC ERROR:
> [0]PETSC ERROR: Petsc Release Version 3.2.0, Patch 6, Wed Jan 11 09:28:45
> CST 2012
> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [0]PETSC ERROR: See docs/index.html for manual pages.
> Portion of the code which I use to set the solver contents follows (I am
> aiming at CG+ICC combination):
>   /* Create KPS content */
>   KSPCreate(PETSC_COMM_WORLD, &ksp);
>   KSPSetType(ksp ,KSPCG);
>   /* Set operators */
>   KSPSetOperators(ksp, A, A, DIFFERENT_NONZERO_PATTERN);
>   /* Linear solver defaults (can be ove-ridden) */
>   KSPGetPC(ksp, &pc);
>   PCSetType(pc, PCICC);
>   KSPSetTolerances(ksp, 1.e-5, PETSC_DEFAULT, PETSC_DEFAULT,
> PETSC_DEFAULT);
>   /* Run-time options (over-rides above) */
>   KSPSetFromOptions(ksp);
> What is going wrong here?
>     Kind regards,
>     Bojan
> On 2/26/2012 6:17 PM, Matthew Knepley wrote:
> On Sun, Feb 26, 2012 at 10:48 AM, Max Rudolph <maxwellr at gmail.com> wrote:
>> MPIAIJ and SEQQIJ matrices are subtypes of the AIJ matrix type. Looking
>> at that table, you should be able to use any of the PCs that supports AIJ
>> and has an X under 'parallel'.
>  Max is correct. For instance, the most popular general purpose parallel
> solver is ASM (Additive Schwarz Method), which then
> has a sequential subsolver for each block, which defaults to ILU.
>     Matt
>>  Max
>> On Sun, Feb 26, 2012 at 8:16 AM, Aron Roland <aaronroland at gmx.de> wrote:
>>> Dear All,
>>> I hope somebody can help us on this or give at least some clearance.
>>> We have just included PETSc as an solver for our sparse matrix evolving
>>> from an unstructured mesh advection scheme.
>>> The problem is that we are using the mpiaij matrix type, since our
>>> matrix is naturally sparse. However it seems that PETSc has no PC for this,
>>> except the PCSOR, which showed to be not very effective for our problem.
>>> All others give the error msg. of the mail subject, where XXX are the
>>> different PC tried.
>>> The manual is a bit diffuse on this e.g.
>>> http://www.mcs.anl.gov/petsc/documentation/linearsolvertable.html
>>> it is claimed that certain PC's are running on aij matrices ... but
>>> these are to be defined either as seq. or parallel (mpiaij) matrices.
>>> Moreover in the above mentioned list are two columns parallel/seriel, what
>>> is the intention of parallel capability when not applicable to matrices
>>> stored within the parallel mpiaij framework.
>>> I guess we just not understanding the concept or have some other
>>> difficulties of understanding of all this.
>>> Any comments help is welcome
>>> Aron
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120228/d43708e1/attachment.htm>
Name: not available
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120228/d43708e1/attachment.png>
Name: not available
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120228/d43708e1/attachment-0001.png>
