[petsc-users] Matrix format mpiaij does not have a built-in PETSc XXX!
Bojan Niceno bojan.niceno at psi.ch
Tue Feb 28 11:06:14 CST 2012
Hi all,
On 2/28/2012 5:41 PM, Matthew Knepley wrote:
> Look, I already replied to this, and now Jed had to reply again. If
> you are not going to read our mail, why mail the list?
I am reading your messages, all right, but I also read PETSc's errors
and manuals.
Look what the manual says on ICC:
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCICC.html
"Notes: Only implemented for some matrix formats. Not implemented in
parallel."
And on ILU:
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCILU.html
"Notes: Only implemented for some matrix formats. (for parallel see
PCHYPRE
<http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCHYPRE.html#PCHYPRE>
for hypre's ILU)"
So Matt, if I understand your answer correctly, one should use PCASM to
get ILU in parallel, right?  What if I want IC?
     Bojan
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120228/26731470/attachment-0001.htm>
