[petsc-users] Matrix format mpiaij does not have a built-in PETSc XXX!
Bojan Niceno bojan.niceno at psi.ch
Tue Feb 28 03:19:55 CST 2012
On 2/28/2012 10:04 AM, Aron Roland wrote:
> Hi Bojan,
> the PCILU package does not work with mpiaij matrices, same as PCICC.
> Basically only PCSOR works.
Auch :-(  When I saw your reply, I was hoping you will say: "I've found
a resolution in the meantime", but you only confirmed my fears.
     Cheers
     Bojan
> You can install the hypre package then you can use the hypre solvers
> that also include an ILU PC names BILUT, however I did not had any
> success to achieve convergence, even if my SPARSKIT ILU-BCGSTAB
> converges very well.
> Hope this helped.
> Cheers
> Aron
> On 02/28/2012 08:47 AM, Bojan Niceno wrote:
>> Dear all,
>> Max may be correct, but I encounter the same problem as Aron.
>> Neither PCILU nor PCICC work in parallel for me.  Here is the message
>> I get:
>> [0]PETSC ERROR: --------------------- Error Message
>> [0]PETSC ERROR: No support for this operation for this object type!
>> [0]PETSC ERROR: Matrix format mpiaij does not have a built-in PETSc ICC!
>> [0]PETSC ERROR:
>> [0]PETSC ERROR: Petsc Release Version 3.2.0, Patch 6, Wed Jan 11
>> 09:28:45 CST 2012
>> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
>> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>> [0]PETSC ERROR: See docs/index.html for manual pages.
>> Portion of the code which I use to set the solver contents follows (I
>> am aiming at CG+ICC combination):
>> /* Create KPS content */
>>   KSPCreate(PETSC_COMM_WORLD, &ksp);
>>   KSPSetType(ksp ,KSPCG);
>>   /* Set operators */
>>   KSPSetOperators(ksp, A, A, DIFFERENT_NONZERO_PATTERN);
>>   /* Linear solver defaults (can be ove-ridden) */
>>   KSPGetPC(ksp, &pc);
>>   PCSetType(pc, PCICC);
>>   KSPSetTolerances(ksp, 1.e-5, PETSC_DEFAULT, PETSC_DEFAULT,
>> PETSC_DEFAULT);
>>   /* Run-time options (over-rides above) */
>>   KSPSetFromOptions(ksp);
>> What is going wrong here?
>>     Kind regards,
>>     Bojan
>> On 2/26/2012 6:17 PM, Matthew Knepley wrote:
>>> On Sun, Feb 26, 2012 at 10:48 AM, Max Rudolph <maxwellr at gmail.com
>>> <mailto:maxwellr at gmail.com>> wrote:
>>>     MPIAIJ and SEQQIJ matrices are subtypes of the AIJ matrix type.
>>>     Looking at that table, you should be able to use any of the PCs
>>>     that supports AIJ and has an X under 'parallel'.
>>> Max is correct. For instance, the most popular general purpose
>>> parallel solver is ASM (Additive Schwarz Method), which then
>>> has a sequential subsolver for each block, which defaults to ILU.
>>>    Matt
>>>     Max
>>>     On Sun, Feb 26, 2012 at 8:16 AM, Aron Roland <aaronroland at gmx.de
>>>     <mailto:aaronroland at gmx.de>> wrote:
>>>         Dear All,
>>>         I hope somebody can help us on this or give at least some
>>>         clearance.
>>>         We have just included PETSc as an solver for our sparse
>>>         matrix evolving from an unstructured mesh advection scheme.
>>>         The problem is that we are using the mpiaij matrix type,
>>>         since our matrix is naturally sparse. However it seems that
>>>         PETSc has no PC for this, except the PCSOR, which showed to
>>>         be not very effective for our problem.
>>>         All others give the error msg. of the mail subject, where
>>>         XXX are the different PC tried.
>>>         The manual is a bit diffuse on this e.g.
>>>         http://www.mcs.anl.gov/petsc/documentation/linearsolvertable.html
>>>         it is claimed that certain PC's are running on aij matrices
>>>         ... but these are to be defined either as seq. or parallel
>>>         (mpiaij) matrices. Moreover in the above mentioned list are
>>>         two columns parallel/seriel, what is the intention of
>>>         parallel capability when not applicable to matrices stored
>>>         within the parallel mpiaij framework.
>>>         I guess we just not understanding the concept or have some
>>>         other difficulties of understanding of all this.
>>>         Any comments help is welcome
>>>         Aron
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which
>>> their experiments lead.
>>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120228/4902439f/attachment.htm>
Name: not available
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120228/4902439f/attachment.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120228/4902439f/attachment-0001.png>
