[petsc-users] KSP_PCApply Documentation?
Bibrak Qamar
bibrakc at gmail.com
Sat Feb 18 23:58:09 CST 2012
Thank you very much.
Bibrak
On Fri, Feb 17, 2012 at 5:27 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Fri, Feb 17, 2012 at 03:27, Bibrak Qamar <bibrakc at gmail.com> wrote:
>> I found the the above function used in KSPSolve_CG but couldn't find its
>> documentation. I will appreciate any help in this direction.
> It is not a public function, so if you want to look at it, you'll need to
> read the source. You should follow the instructions in the user's manual to
> set up tags with your editor so you can easily jump to the definitions.
> #define KSP_PCApply(ksp,x,y) (!ksp->transpose_solve) ?
> (PCApply(ksp->pc,x,y) || KSP_RemoveNullSpace(ksp,y)) :
> PCApplyTranspose(ksp->pc,x,y)
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120219/d309fc00/attachment.htm>
