[petsc-users] PETSc fortran type check
Panruo Wu
pwu at mymail.mines.edu
Mon Aug 27 15:14:11 CDT 2012
Thanks
Panruo
On Mon, Aug 27, 2012 at 2:00 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Aug 27, 2012 at 2:59 PM, Panruo Wu <pwu at mymail.mines.edu> wrote:
>> Mat,
>> Could you give some details on how I can find all the unchecked(checked)
>> subroutines so that I can narrow down my search area when
>> segfaults occur?
> The right way to narrow this down is to use -start_in_debugger since you
> will
> immediately get the stack trace showing the offending method.
> Matt
>> Thanks
>> panruo
>> On Mon, Aug 27, 2012 at 1:47 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>> On Mon, Aug 27, 2012 at 2:46 PM, Panruo Wu <pwu at mymail.mines.edu> wrote:
>>>> Hello PETSC developers and users,
>>>> I read on link
>>>> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/UsingFortran.html
>>>> that approach 2 & 3 have some type check functionalities. My question
>>>> is which subroutines
>>>> are type checked and which are not. For example I guess that
>>>> DMDACreate3d is checked
>>>> (I'm using approach 3).
>>> The ones with interface declarations.
>>> Matt
>>>> Thanks and best wishes,
>>>> Panruo Wu
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120827/35724382/attachment.html>
