[petsc-users] PETSc fortran type check
Mon Aug 27 15:00:44 CDT 2012
On Mon, Aug 27, 2012 at 2:59 PM, Panruo Wu <pwu at mymail.mines.edu> wrote:
> Mat,
> Could you give some details on how I can find all the unchecked(checked)
> subroutines so that I can narrow down my search area when
> segfaults occur?
The right way to narrow this down is to use -start_in_debugger since you
will
immediately get the stack trace showing the offending method.
   Matt
> Thanks
> panruo
> On Mon, Aug 27, 2012 at 1:47 PM, Matthew Knepley <knepley at gmail.com>wrote:
>> On Mon, Aug 27, 2012 at 2:46 PM, Panruo Wu <pwu at mymail.mines.edu> wrote:
>>> Hello PETSC developers and users,
>>> I read on link
>>> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/UsingFortran.html
>>> that approach 2 & 3 have some type check functionalities.  My question
>>> is which subroutines
>>> are type checked and which are not.  For example I guess that
>>> DMDACreate3d is checked
>>> (I'm using approach 3).
>> The ones with interface declarations.
>>    Matt
>>> Thanks and best wishes,
>>> Panruo Wu
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120827/49670fd6/attachment.html>
