[petsc-users] The possibility of applying DA to governing multi-block data structure
Matthew Knepley
knepley at gmail.com
Mon Aug 27 14:59:59 CDT 2012
On Sun, Aug 26, 2012 at 10:29 PM, C.-C. Chiou <ccchiou2012 at gmail.com> wrote:
> Matt,
> Thank you.
> Now, I'm dealing with a work like that: (for example)
> ______
> ________ | |
> | f1 | f2 |
> |________ | |
> |_____ |
> (or please see the attached file "blocks_fig1.png" )
> I have a physical domain partitioned into two blocks f1 and f2 (or more
> for other case),
> and I need to solve Navier-Stoke equations concerning on such domain by
> multi-block solver,
> with two connected structured meshes respectively for f1 and f2.
> I wonder whether case like the above for example is considered as one of
> experiment.
So for this case we have no easy support. You would have to manually
construct a VecScatter
object which encoded the coupling between the meshes, and there really are
not any examples
of this. Note that Hypre does have a specific interface for this (I think
its SStruct).
Matt
> Regards.
> Chuei-Ching Chiou
> On Wed, Aug 22, 2012 at 6:50 PM, Matthew Knepley <knepley at gmail.com>wrote:
>> On Wed, Aug 22, 2012 at 2:52 AM, C.-C. Chiou <ccchiou2012 at gmail.com>wrote:
>>> Dear Mathew,
>>> Thanks for your response!
>>> At line 645 in the source code,
>>> http://www.mcs.anl.gov/petsc/petsc-dev/include/petscsnes.h.html ,
>>> some SNES routines for multi-block solver were listed.
>>> Is there any source code for specific testing PDE problem with these
>>> routines?
>> That is an experiment that does not yet work.
>>> In addition, is the KSP version available?
>> Its called ASM.
>> Matt
>>> Sincerely regards.
>>> Chuei-Ching Chiou
>>> On Wed, Aug 8, 2012 at 9:06 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>> On Wed, Aug 8, 2012 at 2:30 AM, C.-C. Chiou <ccchiou2012 at gmail.com>wrote:
>>>>> Dear all,
>>>>> For concerning more general geometry of physical domain, for some
>>>>> situations,
>>>>> we need to apply the multi-block mesh. The attached figure (or
>>>>> alternatively the following link) illustrates one of examples.
>>>>> https://dl.dropbox.com/u/17189529/share_documents/IMAG0003.jpg
>>>>> Have you ever dealt with such kind of case with application of the
>>>>> PETSc object 'DA' ?
>>>> Our intention for this is that you use a DMComposite structure. Let us
>>>> know if the documentation is unclear
>>>> on anything, since it is somewhat new.
>>>> Thanks,
>>>> Matt
>>>>> Suppose we build multiple DA(or DM) for governing the multi-block data
>>>>> structure,
>>>>> in other words, we respectively build a DA for each block of mesh.
>>>>> Especially in parallel computing,
>>>>> how can we manage and control the communications between blocks of
>>>>> data accurately and efficiently?
>>>>> And, how can we ensure the correctness of parallel computational
>>>>> results?
>>>>> I wonder whether some possible application of PETSc object 'DA' (or
>>>>> DM) is sufficient for dealing with cases in multi-block mesh.
>>>>> Sincerely regards.
>>>>> Chuei-Ching Chiou
>>>>> Chuei-Ching Chiou,
>>>>> Ph. D student,
>>>>> Aerothermal & Plasma Physics Laboratory
>>>>> Department of Mechanical Engineering
>>>>> National Chiao Tung University
>>>>> Hsinchu 30010, TAIWAN
>>>>> TEL: +886-35712121 ext. 55175
>>>>> E-mail: C <staystay.me99g at g2.nctu.edu.tw>CChiou2012 at gmail.com
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to which their
>>>> experiments lead.
>>>> -- Norbert Wiener
>>> Chuei-Ching Chiou,
>>> Ph. D student,
>> experiments lead.
>> -- Norbert Wiener
> Chuei-Ching Chiou,
> Ph. D student,
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120827/45f1f2f3/attachment-0001.html>
