[petsc-users] The possibility of applying DA to governing multi-block data structure
C.-C. Chiou
ccchiou2012 at gmail.com
Mon Aug 27 20:13:06 CDT 2012
Matt,
Thanks a lot!
I'll try your suggestions.
Chuei-Ching Chiou
On Tue, Aug 28, 2012 at 3:59 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Sun, Aug 26, 2012 at 10:29 PM, C.-C. Chiou <ccchiou2012 at gmail.com>wrote:
>> Matt,
>> Thank you.
>> Now, I'm dealing with a work like that: (for example)
>> ______
>> ________ | |
>> | f1 | f2 |
>> |________ | |
>> |_____ |
>> (or please see the attached file "blocks_fig1.png" )
>> I have a physical domain partitioned into two blocks f1 and f2 (or more
>> for other case),
>> and I need to solve Navier-Stoke equations concerning on such domain by
>> multi-block solver,
>> with two connected structured meshes respectively for f1 and f2.
>> I wonder whether case like the above for example is considered as one of
>> experiment.
> So for this case we have no easy support. You would have to manually
> construct a VecScatter
> object which encoded the coupling between the meshes, and there really are
> not any examples
> of this. Note that Hypre does have a specific interface for this (I think
> its SStruct).
> Thanks,
> Matt
>> Regards.
>> Chuei-Ching Chiou
>> On Wed, Aug 22, 2012 at 6:50 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>> On Wed, Aug 22, 2012 at 2:52 AM, C.-C. Chiou <ccchiou2012 at gmail.com>wrote:
>>>> Dear Mathew,
>>>> Thanks for your response!
>>>> At line 645 in the source code,
>>>> http://www.mcs.anl.gov/petsc/petsc-dev/include/petscsnes.h.html ,
>>>> some SNES routines for multi-block solver were listed.
>>>> Is there any source code for specific testing PDE problem with these
>>>> routines?
>>> That is an experiment that does not yet work.
>>>> In addition, is the KSP version available?
>>> Its called ASM.
>>> Matt
>>>> Sincerely regards.
>>>> Chuei-Ching Chiou
>>>> On Wed, Aug 8, 2012 at 9:06 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>>> On Wed, Aug 8, 2012 at 2:30 AM, C.-C. Chiou <ccchiou2012 at gmail.com>wrote:
>>>>>> Dear all,
>>>>>> For concerning more general geometry of physical domain, for some
>>>>>> situations,
>>>>>> we need to apply the multi-block mesh. The attached figure (or
>>>>>> alternatively the following link) illustrates one of examples.
>>>>>> https://dl.dropbox.com/u/17189529/share_documents/IMAG0003.jpg
>>>>>> Have you ever dealt with such kind of case with application of the
>>>>>> PETSc object 'DA' ?
>>>>> Our intention for this is that you use a DMComposite structure. Let us
>>>>> know if the documentation is unclear
>>>>> on anything, since it is somewhat new.
>>>>> Thanks,
>>>>> Matt
>>>>>> Suppose we build multiple DA(or DM) for governing the multi-block
>>>>>> data structure,
>>>>>> in other words, we respectively build a DA for each block of mesh.
>>>>>> Especially in parallel computing,
>>>>>> how can we manage and control the communications between blocks of
>>>>>> data accurately and efficiently?
>>>>>> And, how can we ensure the correctness of parallel computational
>>>>>> results?
>>>>>> I wonder whether some possible application of PETSc object 'DA' (or
>>>>>> DM) is sufficient for dealing with cases in multi-block mesh.
>>>>>> Sincerely regards.
>>>>>> Chuei-Ching Chiou
>>>>>> Chuei-Ching Chiou,
>>>>>> Ph. D student,
>>>>>> Aerothermal & Plasma Physics Laboratory
>>>>>> Department of Mechanical Engineering
>>>>>> National Chiao Tung University
>>>>>> Hsinchu 30010, TAIWAN
>>>>>> TEL: +886-35712121 ext. 55175
>>>>>> E-mail: C <staystay.me99g at g2.nctu.edu.tw>CChiou2012 at gmail.com
>>>>> What most experimenters take for granted before they begin their
>>>>> experiments is infinitely more interesting than any results to which their
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>>> Chuei-Ching Chiou,
>>>> Ph. D student,
>>> experiments lead.
>>> -- Norbert Wiener
>> Chuei-Ching Chiou,
>> Ph. D student,
> experiments lead.
> -- Norbert Wiener
Chuei-Ching Chiou,
Ph. D student,
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120828/c45c344d/attachment.html>
