[petsc-users] The possibility of applying DA to governing multi-block data structure
C.-C. Chiou
ccchiou2012 at gmail.com
Sun Aug 26 22:29:32 CDT 2012
Matt,
Thank you.
Now, I'm dealing with a work like that: (for example)
______
________ | |
| f1 | f2 |
|________ | |
|_____ |
(or please see the attached file "blocks_fig1.png" )
I have a physical domain partitioned into two blocks f1 and f2 (or more for
other case),
and I need to solve Navier-Stoke equations concerning on such domain by
multi-block solver,
with two connected structured meshes respectively for f1 and f2.
I wonder whether case like the above for example is considered as one of
experiment.
Regards.
Chuei-Ching Chiou
On Wed, Aug 22, 2012 at 6:50 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, Aug 22, 2012 at 2:52 AM, C.-C. Chiou <ccchiou2012 at gmail.com>wrote:
>> Dear Mathew,
>> Thanks for your response!
>> At line 645 in the source code,
>> http://www.mcs.anl.gov/petsc/petsc-dev/include/petscsnes.h.html ,
>> some SNES routines for multi-block solver were listed.
>> Is there any source code for specific testing PDE problem with these
>> routines?
> That is an experiment that does not yet work.
>> In addition, is the KSP version available?
> Its called ASM.
> Matt
>> Sincerely regards.
>> Chuei-Ching Chiou
>> On Wed, Aug 8, 2012 at 9:06 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>> On Wed, Aug 8, 2012 at 2:30 AM, C.-C. Chiou <ccchiou2012 at gmail.com>wrote:
>>>> Dear all,
>>>> For concerning more general geometry of physical domain, for some
>>>> situations,
>>>> we need to apply the multi-block mesh. The attached figure (or
>>>> alternatively the following link) illustrates one of examples.
>>>> https://dl.dropbox.com/u/17189529/share_documents/IMAG0003.jpg
>>>> Have you ever dealt with such kind of case with application of the
>>>> PETSc object 'DA' ?
>>> Our intention for this is that you use a DMComposite structure. Let us
>>> know if the documentation is unclear
>>> on anything, since it is somewhat new.
>>> Thanks,
>>> Matt
>>>> Suppose we build multiple DA(or DM) for governing the multi-block data
>>>> structure,
>>>> in other words, we respectively build a DA for each block of mesh.
>>>> Especially in parallel computing,
>>>> how can we manage and control the communications between blocks of data
>>>> accurately and efficiently?
>>>> And, how can we ensure the correctness of parallel computational
>>>> results?
>>>> I wonder whether some possible application of PETSc object 'DA' (or DM)
>>>> is sufficient for dealing with cases in multi-block mesh.
>>>> Sincerely regards.
>>>> Chuei-Ching Chiou
>>>> Chuei-Ching Chiou,
>>>> Ph. D student,
>>>> Aerothermal & Plasma Physics Laboratory
>>>> Department of Mechanical Engineering
>>>> National Chiao Tung University
>>>> Hsinchu 30010, TAIWAN
>>>> TEL: +886-35712121 ext. 55175
>>>> E-mail: C <staystay.me99g at g2.nctu.edu.tw>CChiou2012 at gmail.com
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>> Chuei-Ching Chiou,
>> Ph. D student,
> experiments lead.
> -- Norbert Wiener
Chuei-Ching Chiou,
Ph. D student,
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120827/143217af/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120827/143217af/attachment-0001.png>
