[petsc-users] Nullspace for a coupled system of equations
    Matthew Knepley
    knepley at gmail.com
    Fri Aug 17 14:39:42 CDT 2012
On Fri, Aug 17, 2012 at 2:27 PM, Thomas Witkowski <
thomas.witkowski at tu-dresden.de> wrote:
>  On Fri, Aug 17, 2012 at 3:10 AM, Thomas Witkowski <
>    I want to solve some (weakly) coupled system of equations of the
>>> following form:
>>> A  B     u
>>> 0  C     v
>>> so, C is the discrete Laplacian and A and B are some more complicated
>>> operators (I make use of linear finite elements). All boundary conditions
>>> are periodic, so the unknown v is determined only up to a constant. A and B
>>> contain both the identity operator, so u is fixed. Now I want to solve the
>>> system on the whole (there are reasons to do it in this way!) and I must
>>> provide information about the nullspace to the solver. When I am right, to
>>> provide the correct nullspace I must solve one equation with A. Is there
>>> any way in PETSc to circumvent the problem?
>>  If I understand you correctly, your null space vector is (0 I). I use
>> the same null space for SNES ex62.
>> (0 I) cannot be an element of the null space, as multiplying it with the
>> matrix results in a non-zero vector. Or am I totally wrong about null
>> spaces of matrices?
>  Maybe you could as your question again. I am not understanding what you
> want.
>   I want to solve the block triangular system as described above. My
> problem is, that it has a one dimensional null space, but I'm not able to
> define it. My question is: does anyone can give me an advice how to EITHER
> compute the null space explicitly OR how to solve the system in such a way
> that the null space is considered by the solver. The only constraint is
> that I cannot split the system of equations into two independent solve for
> both variables. I know that from this description its not clear why there
> is this constraint, but it would take too long to describe it.
What is your evidence that it has a null space?
   Matt
> Thomas
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120817/b7386307/attachment.html>
