[petsc-users] 64 bit integers
Michele Rosso
mrosso at uci.edu
Fri Aug 17 11:04:07 CDT 2012
Thank you.
How can I convert?
Michele
On 08/17/2012 08:55 AM, Matthew Knepley wrote:
> On Fri, Aug 17, 2012 at 10:16 AM, Jed Brown <jedbrown at mcs.anl.gov
> <mailto:jedbrown at mcs.anl.gov>> wrote:
> On Fri, Aug 17, 2012 at 10:12 AM, Michele Rosso <mrosso at uci.edu
> <mailto:mrosso at uci.edu>> wrote:
> Does this mean that Fortran compiler invoked by the PETSc
> Makefile will
> compile to code with the 64 bit integer option so that also
> Fortran Integer will be 64 bit?
> NO, that would be bad because it breaks library interfaces.
> You have to use the right types internally. If you use PetscInt
> everywhere, then you'll be fine. If you mix types, you have to
> find out where to convert.
> I meant that if you use PetscInt in Fortran it was also be a 64-bit
> integer.
> Matt
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120817/fe453ef3/attachment.html>
