[petsc-users] 64 bit integers
Fri Aug 17 10:55:43 CDT 2012
On Fri, Aug 17, 2012 at 10:16 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Fri, Aug 17, 2012 at 10:12 AM, Michele Rosso <mrosso at uci.edu> wrote:
>> Does this mean that Fortran compiler invoked by the PETSc Makefile will
>> compile to code with the 64 bit integer option so that also Fortran
>> Integer will be 64 bit?
> NO, that would be bad because it breaks library interfaces.
> You have to use the right types internally. If you use PetscInt
> everywhere, then you'll be fine. If you mix types, you have to find out
> where to convert.
I meant that if you use PetscInt in Fortran it was also be a 64-bit integer.
   Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120817/b2d8d628/attachment.html>
