[petsc-users] 64 bit integers
Matthew Knepley
knepley at gmail.com
Fri Aug 17 11:08:01 CDT 2012
On Fri, Aug 17, 2012 at 11:04 AM, Michele Rosso <mrosso at uci.edu> wrote:
> Thank you.
> How can I convert?
Don't use integer, use PetscInt. See any PETSc example.
Matt
> Michele
> On 08/17/2012 08:55 AM, Matthew Knepley wrote:
> On Fri, Aug 17, 2012 at 10:16 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>> On Fri, Aug 17, 2012 at 10:12 AM, Michele Rosso <mrosso at uci.edu> wrote:
>>> Does this mean that Fortran compiler invoked by the PETSc Makefile will
>>> compile to code with the 64 bit integer option so that also Fortran
>>> Integer will be 64 bit?
>> NO, that would be bad because it breaks library interfaces.
>> You have to use the right types internally. If you use PetscInt
>> everywhere, then you'll be fine. If you mix types, you have to find out
>> where to convert.
> I meant that if you use PetscInt in Fortran it was also be a 64-bit
> integer.
> Matt
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120817/36deebf1/attachment.html>
