[petsc-users] Field split questions
Sanjay Govindjee s_g at berkeley.edu
Thu Aug 9 09:21:06 CDT 2012
Colin,
   I you block the equations in FEAP, then the restrained BCs are
'included' in assembled PETSc matrix (these dofs have rows that are zero
modulo a value of unity on the diagonal and the restrained value on the
right-hand side).
-sg
On 8/9/12 8:41 AM, Colin McAuliffe wrote:
> From what I can gather from the petsc-dev source it looks like the
> commands in 4) will then generate the splits using strided blocks. The
> problem with that is the fortran code I am using (FEAP) uses petsc to
> assemble and solve the linear problem within its own nonlinear and
> time stepping schemes. The linear problem that petsc solves already
> has boundary conditions applied to it so petsc only sees the active
> (unrestrained) equations. So then in general fields can't be extracted
> from the active equations using strided blocks and I am stuck with
> generating the index sets defining the splits on my own. Will it still
> be possible to make use of the new DM functions in this case?
> FEAP website:
> http://www.ce.berkeley.edu/projects/feap/
> Colin
> Quoting Matthew Knepley <knepley at gmail.com>:
>> On Wed, Aug 8, 2012 at 10:51 PM, Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Wed, Aug 8, 2012 at 10:23 PM, Colin McAuliffe
>>> <cjm2176 at columbia.edu>wrote:
>>>> Thanks all, regarding use of DM in 3.3, is the procedure now to create
>>>> the fields with PCFieldSplitSetIS and then use
>>>> DMCreateFieldDecompositionDM
>>>> to create a new DM based from the new fields and the DM for the
>>>> original
>>>> problem?
>>> 1) Use petsc-dev
>>> 2) PCFieldSplitSetIS() is independent. This allows you to define splits
>>> however you want, but then recursive gets harder
>>> 3) In 3.3., it uses DMCreateFieldDecompositionDM() to split all fields
>>> apart at once
>>> 4) In petsc-dev, it uses DMCreateSubDM() which can split off any
>>> combination of fields, which from the command line is something like
>>>      -pc_fieldsplit_0_fields 2,0 -pc_fieldsplit_1_fields 1,3
>> I should have shown recursive:
>>   -fieldsplit_0_pc_type fieldsplit
>> will split 2,0 into two blocks.
>>    Matt
>>>      Matt
>>>> Colin
>>>> Colin McAuliffe
>>>> PhD Candidate
>>>> Columbia University
>>>> Department of Civil Engineering and Engineering Mechanics
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which
>>> their
>>> experiments lead.
>>> -- Norbert Wiener
>> their
>> experiments lead.
>> -- Norbert Wiener
Sanjay Govindjee, PhD, PE
Professor of Civil Engineering
Vice Chair for Academic Affairs
779 Davis Hall
Structural Engineering, Mechanics and Materials
University of California
Berkeley, CA 94720-1710
Voice:  +1 510 642 6060
FAX:    +1 510 643 5264
s_g at berkeley.edu
http://www.ce.berkeley.edu/~sanjay
