[petsc-users] Field split questions
Thu Aug 9 08:14:29 CDT 2012
On Thu, Aug 9, 2012 at 7:41 AM, Colin McAuliffe <cjm2176 at columbia.edu>wrote:
> From what I can gather from the petsc-dev source it looks like the
> commands in 4) will then generate the splits using strided blocks. The
> problem with that is
No. I never use strided blocks.
   Matt
> the fortran code I am using (FEAP) uses petsc to assemble and solve the
> linear problem within its own nonlinear and time stepping schemes. The
> linear problem that petsc solves already has boundary conditions applied to
> it so petsc only sees the active (unrestrained) equations. So then in
> general fields can't be extracted from the active equations using strided
> blocks and I am stuck with generating the index sets defining the splits on
> my own. Will it still be possible to make use of the new DM functions in
> this case?
> FEAP website:
> http://www.ce.berkeley.edu/**projects/feap/<http://www.ce.berkeley.edu/projects/feap/>
> Colin
> Quoting Matthew Knepley <knepley at gmail.com>:
>  On Wed, Aug 8, 2012 at 10:51 PM, Matthew Knepley <knepley at gmail.com>
>> wrote:
>>  On Wed, Aug 8, 2012 at 10:23 PM, Colin McAuliffe  <cjm2176 at columbia.edu
>>> >wrote:
>>>  Thanks all, regarding use of DM in 3.3, is the procedure now to create
>>>> the fields with PCFieldSplitSetIS and then use
>>>> DMCreateFieldDecompositionDM
>>>> to create a new DM based from the new fields and the DM for the original
>>>> problem?
>>> 1) Use petsc-dev
>>> 2) PCFieldSplitSetIS() is independent. This allows you to define splits
>>> however you want, but then recursive gets harder
>>> 3) In 3.3., it uses DMCreateFieldDecompositionDM() to split all fields
>>> apart at once
>>> 4) In petsc-dev, it uses DMCreateSubDM() which can split off any
>>> combination of fields, which from the command line is something like
>>>      -pc_fieldsplit_0_fields 2,0 -pc_fieldsplit_1_fields 1,3
>> I should have shown recursive:
>>   -fieldsplit_0_pc_type fieldsplit
>> will split 2,0 into two blocks.
>>    Matt
>>       Matt
>>>  Colin
>>>> Colin McAuliffe
>>>> PhD Candidate
>>>> Columbia University
>>>> Department of Civil Engineering and Engineering Mechanics
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which
>>> their
>>> experiments lead.
>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
> Colin McAuliffe
> PhD Candidate
> Columbia University
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120809/27b470c2/attachment-0001.html>
