[petsc-users] Field split questions
Thu Aug 9 09:22:44 CDT 2012
On Thu, Aug 9, 2012 at 9:21 AM, Sanjay Govindjee <s_g at berkeley.edu> wrote:
> Colin,
>   I you block the equations in FEAP, then the restrained BCs are
> 'included' in assembled PETSc matrix (these dofs have rows that are zero
> modulo a value of unity on the diagonal and the restrained value on the
> right-hand side).
However, this is not necessary with the DM interface.
   Matt
> -sg
> On 8/9/12 8:41 AM, Colin McAuliffe wrote:
>> From what I can gather from the petsc-dev source it looks like the
>> commands in 4) will then generate the splits using strided blocks. The
>> problem with that is the fortran code I am using (FEAP) uses petsc to
>> assemble and solve the linear problem within its own nonlinear and time
>> stepping schemes. The linear problem that petsc solves already has boundary
>> conditions applied to it so petsc only sees the active (unrestrained)
>> equations. So then in general fields can't be extracted from the active
>> equations using strided blocks and I am stuck with generating the index
>> sets defining the splits on my own. Will it still be possible to make use
>> of the new DM functions in this case?
>> FEAP website:
>> http://www.ce.berkeley.edu/**projects/feap/<http://www.ce.berkeley.edu/projects/feap/>
>> Colin
>> Quoting Matthew Knepley <knepley at gmail.com>:
>>  On Wed, Aug 8, 2012 at 10:51 PM, Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>>  On Wed, Aug 8, 2012 at 10:23 PM, Colin McAuliffe  <cjm2176 at columbia.edu
>>>> >wrote:
>>>>  Thanks all, regarding use of DM in 3.3, is the procedure now to create
>>>>> the fields with PCFieldSplitSetIS and then use
>>>>> DMCreateFieldDecompositionDM
>>>>> to create a new DM based from the new fields and the DM for the
>>>>> original
>>>>> problem?
>>>> 1) Use petsc-dev
>>>> 2) PCFieldSplitSetIS() is independent. This allows you to define splits
>>>> however you want, but then recursive gets harder
>>>> 3) In 3.3., it uses DMCreateFieldDecompositionDM() to split all fields
>>>> apart at once
>>>> 4) In petsc-dev, it uses DMCreateSubDM() which can split off any
>>>> combination of fields, which from the command line is something like
>>>>      -pc_fieldsplit_0_fields 2,0 -pc_fieldsplit_1_fields 1,3
>>> I should have shown recursive:
>>>   -fieldsplit_0_pc_type fieldsplit
>>> will split 2,0 into two blocks.
>>>    Matt
>>>       Matt
>>>>  Colin
>>>>> Colin McAuliffe
>>>>> PhD Candidate
>>>>> Columbia University
>>>>> Department of Civil Engineering and Engineering Mechanics
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to which
>>>> their
>>>> experiments lead.
>>>> -- Norbert Wiener
>>> their
>>> experiments lead.
>>> -- Norbert Wiener
> Sanjay Govindjee, PhD, PE
> Professor of Civil Engineering
> Vice Chair for Academic Affairs
> 779 Davis Hall
> Structural Engineering, Mechanics and Materials
> University of California
> Berkeley, CA 94720-1710
> Voice:  +1 510 642 6060
> FAX:    +1 510 643 5264
> s_g at berkeley.edu
> http://www.ce.berkeley.edu/~**sanjay <http://www.ce.berkeley.edu/~sanjay>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120809/ded434c2/attachment.html>
