[petsc-users] The possibility of applying DA to governing multi-block data structure
Wed Aug 8 08:06:13 CDT 2012
On Wed, Aug 8, 2012 at 2:30 AM, C.-C. Chiou <ccchiou2012 at gmail.com> wrote:
> Dear all,
> For concerning more general geometry of physical domain, for some
> situations,
> we need to apply the multi-block mesh. The attached figure (or
> alternatively the following link) illustrates one of examples.
> https://dl.dropbox.com/u/17189529/share_documents/IMAG0003.jpg
> Have you ever dealt with such kind of case with application of the PETSc
> object 'DA' ?
Our intention for this is that you use a DMComposite structure. Let us know
if the documentation is unclear
on anything, since it is somewhat new.
     Matt
> Suppose we build multiple DA(or DM) for governing the multi-block data
> structure,
> in other words, we respectively build a DA for each block of mesh.
> Especially in parallel computing,
> how can we manage and control the communications between blocks of data
> accurately and efficiently?
> And, how can we ensure the correctness of parallel computational results?
> I wonder whether some possible application of PETSc object 'DA' (or DM) is
> sufficient for dealing with cases in multi-block mesh.
> Sincerely regards.
> Chuei-Ching Chiou
> Chuei-Ching Chiou,
> Ph. D student,
> Aerothermal & Plasma Physics Laboratory
> Department of Mechanical Engineering
> National Chiao Tung University
> Hsinchu 30010, TAIWAN
> TEL: +886-35712121 ext. 55175
> E-mail: C <staystay.me99g at g2.nctu.edu.tw>CChiou2012 at gmail.com
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120808/fe857921/attachment.html>
