[petsc-users] The possibility of applying DA to governing multi-block data structure
C.-C. Chiou
ccchiou2012 at gmail.com
Wed Aug 22 02:52:55 CDT 2012
Dear Mathew,
Thanks for your response!
At line 645 in the source code,
http://www.mcs.anl.gov/petsc/petsc-dev/include/petscsnes.h.html ,
some SNES routines for multi-block solver were listed.
Is there any source code for specific testing PDE problem with these
routines?
In addition, is the KSP version available?
Sincerely regards.
Chuei-Ching Chiou
On Wed, Aug 8, 2012 at 9:06 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, Aug 8, 2012 at 2:30 AM, C.-C. Chiou <ccchiou2012 at gmail.com> wrote:
>> Dear all,
>> For concerning more general geometry of physical domain, for some
>> situations,
>> we need to apply the multi-block mesh. The attached figure (or
>> alternatively the following link) illustrates one of examples.
>> https://dl.dropbox.com/u/17189529/share_documents/IMAG0003.jpg
>> Have you ever dealt with such kind of case with application of the PETSc
>> object 'DA' ?
> Our intention for this is that you use a DMComposite structure. Let us
> know if the documentation is unclear
> on anything, since it is somewhat new.
> Thanks,
> Matt
>> Suppose we build multiple DA(or DM) for governing the multi-block data
>> structure,
>> in other words, we respectively build a DA for each block of mesh.
>> Especially in parallel computing,
>> how can we manage and control the communications between blocks of data
>> accurately and efficiently?
>> And, how can we ensure the correctness of parallel computational results?
>> I wonder whether some possible application of PETSc object 'DA' (or DM)
>> is sufficient for dealing with cases in multi-block mesh.
>> Sincerely regards.
>> Chuei-Ching Chiou
>> Chuei-Ching Chiou,
>> Ph. D student,
>> Aerothermal & Plasma Physics Laboratory
>> Department of Mechanical Engineering
>> National Chiao Tung University
>> Hsinchu 30010, TAIWAN
>> TEL: +886-35712121 ext. 55175
>> E-mail: C <staystay.me99g at g2.nctu.edu.tw>CChiou2012 at gmail.com
> experiments lead.
> -- Norbert Wiener
Chuei-Ching Chiou,
Ph. D student,
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120822/527a2e12/attachment-0001.html>
