[petsc-users] The possibility of applying DA to governing multi-block data structure
C.-C. Chiou ccchiou2012 at gmail.com
Wed Aug 8 02:30:52 CDT 2012
Dear all,
For concerning more general geometry of physical domain, for some
situations,
we need to apply the multi-block mesh. The attached figure (or
alternatively the following link) illustrates one of examples.
https://dl.dropbox.com/u/17189529/share_documents/IMAG0003.jpg
Have you ever dealt with such kind of case with application of the PETSc
object 'DA' ?
Suppose we build multiple DA(or DM) for governing the multi-block data
structure,
in other words, we respectively build a DA for each block of mesh.
Especially in parallel computing,
how can we manage and control the communications between blocks of data
accurately and efficiently?
And, how can we ensure the correctness of parallel computational results?
I wonder whether some possible application of PETSc object 'DA' (or DM) is
sufficient for dealing with cases in multi-block mesh.
Sincerely regards.
Chuei-Ching Chiou
Chuei-Ching Chiou,
Ph. D student,
Aerothermal & Plasma Physics Laboratory
Department of Mechanical Engineering
National Chiao Tung University
Hsinchu 30010, TAIWAN
TEL: +886-35712121 ext. 55175
E-mail: C <staystay.me99g at g2.nctu.edu.tw>CChiou2012 at gmail.com
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120808/90c43a80/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120808/90c43a80/attachment-0001.jpg>
