[petsc-users] Why does GPU solve the large sparse matrix equations only a little faster than CPU?
Matthew Knepley
knepley at gmail.com
Fri Aug 3 09:28:07 CDT 2012
On Fri, Aug 3, 2012 at 9:18 AM, Xiangze Zeng <zengshixiangze at 163.com> wrote:
> Dear all,
> When I use the CPU solve the equations, it takes 78 minutes, when I change
> to use GPU, it uses 64 minutes, only 15 minutes faster. I see some paper
> say when using PETCs with GPU to solve the large sparse matrix equations,
> it can be several times faster? What's the matter?
For all performance questions, we at least need the output of -log_summary.
However, we would also need to know
- The size and sparsity of your system
- The CPU and GPU you used (saying anything without knowing this is
impossible)
Matt
> Thank you!
> Sincerely,
> Zeng Xiangze
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120803/beeff196/attachment.html>
