[petsc-users] Why does GPU solve the large sparse matrix equations only a little faster than CPU?
Xiangze Zeng
zengshixiangze at 163.com
Fri Aug 3 09:18:13 CDT 2012
Dear all,
When I use the CPU solve the equations, it takes 78 minutes, when I change to use GPU, it uses 64 minutes, only 15 minutes faster. I see some paper say when using PETCs with GPU to solve the large sparse matrix equations, it can be several times faster? What's the matter?
Thank you!
Sincerely,
Zeng Xiangze
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120803/aeb2d679/attachment.html>
