[petsc-users] Save matrix view to postscript?
Barry Smith
bsmith at mcs.anl.gov
Wed Aug 1 12:53:44 CDT 2012
Switching discussion to petsc-maint at mcs.anl.gov so we can track down the problem.
Does this error come up even without -draw_save and -draw_save_movie options?
If yes then please create a new PETSC_ARCH with the exact same ./configure options but NO --with-afterimage. Does this PETSC_ARCH correctly draw X windows without the error?
Barry
On Aug 1, 2012, at 12:07 PM, Ronald M. Caplan <caplanr at predsci.com> wrote:
> After configuring with --with-afterimage I now cannot even get eh x-windows to show the matrix at all. I get the following error:
> X Error of failed request: BadValue (integer parameter out of range for operation)
> Major opcode of failed request: 1 (X_CreateWindow)
> Value in failed request: 0xae
> Serial number of failed request: 7
> Current serial number in output stream: 14
> - Ron
> On Tue, Jul 31, 2012 at 4:20 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Tue, Jul 31, 2012 at 4:13 PM, Ronald M. Caplan <caplanr at predsci.com> wrote:
> Thanks!
> I can't seem to get it to work though.
> When I configure --with-afterimage it says that I need to download it. When I use --download-afterimage it says:
> "External package afterimage does not support --download-afterimage"
> I am using a MAC with OS X. Where can I download afterimage?
> http://www.afterstep.org/afterimage/
> Also, in general, if I want to add a configure to petsc with ./configure, do I have to run ./configure with ALL my options, or just with the new ones I want to add/change? Will it save my previous configure?
> Run $PETSC_ARCH/conf/reconfigure-*.py --new-options
> Thanks again for your rapid responses!
> - Ron C
> On Tue, Jul 31, 2012 at 3:23 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> Sorry the postscript never really worked and then the world went PDF.
> You can do what you want in PETSc 3.3 with
> ierr = PetscOptionsBool("-draw_save_movie","Make a movie from the images saved","PetscDrawSetSave",movie,&movie,PETSC_NULL);CHKERRQ(ierr);
> ierr = PetscOptionsString("-draw_save","Save graphics to file","PetscDrawSetSave",filename,filename,PETSC_MAX_PATH_LEN,&save);CHKERRQ(ierr);
> /*@C
> PetscDrawSave - Saves images produced in a PetscDraw into a file as a Gif file using AfterImage
> Collective on PetscDraw
> Input Parameter:
> + draw - the graphics context
> . filename - name of the file, if PETSC_NULL uses name of draw object
> - movie - produce a movie of all the images
> Options Database Command:
> + -draw_save <filename>
> - -draw_save_movie
> Level: intermediate
> Concepts: X windows^graphics
> Concepts: drawing^postscript
> Concepts: postscript^graphics
> Concepts: drawing^Microsoft Windows
> Notes: Requires that PETSc be configured with the option --with-afterimage
> .seealso: PetscDrawSetFromOptions(), PetscDrawCreate(), PetscDrawDestroy(), PetscDrawSave()
> Please report any problems to petsc-maint at mcs.anl.gov
> Note that you must make sure the windows being saved are not covered by other windows.
> Barry
> On Jul 31, 2012, at 3:17 PM, "Ronald M. Caplan" <caplanr at predsci.com> wrote:
> > Hi,
> > I saw online that back in 2006 there was a way to tell PETSc to save the image in -mat_view_draw into a postscript file. Is there anyway to still do this? Or to same the image into any format? Or to save a movie of the residual images in ksp?
> > Thanks,
> > Ron C.
