[petsc-users] Save matrix view to postscript?
    Ronald M. Caplan
    caplanr at predsci.com
    Wed Aug  1 12:56:19 CDT 2012
Yes, the error occurs when I use -mat_view_draw even without -draw_save.
My previous pets configuration was identical to mine but without the
--with-afterimage and the matrices showed up in xwindows.
I downloaded and installed the latest afterimage and ffmpeg.
 - Ron C
On Wed, Aug 1, 2012 at 10:53 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   Switching discussion to petsc-maint at mcs.anl.gov so we can track down
> the problem.
>   Does this error come up even without -draw_save and -draw_save_movie
> options?
>   If yes then please create a new PETSC_ARCH with the exact same
> ./configure options but NO --with-afterimage.   Does this PETSC_ARCH
> correctly draw X windows without the error?
>    Barry
> On Aug 1, 2012, at 12:07 PM, Ronald M. Caplan <caplanr at predsci.com> wrote:
> > After configuring with --with-afterimage I now cannot even get eh
> x-windows to show the matrix at all.  I get the following error:
> > X Error of failed request:  BadValue (integer parameter out of range for
> operation)
> >   Major opcode of failed request:  1 (X_CreateWindow)
> >   Value in failed request:  0xae
> >   Serial number of failed request:  7
> >   Current serial number in output stream:  14
> >  - Ron
> > On Tue, Jul 31, 2012 at 4:20 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> > On Tue, Jul 31, 2012 at 4:13 PM, Ronald M. Caplan <caplanr at predsci.com>
> wrote:
> > Thanks!
> > I can't seem to get it to work though.
> > When I configure --with-afterimage it says that I need to download it.
>  When I use --download-afterimage it says:
> > "External package afterimage does not support --download-afterimage"
> > I am using a MAC with OS X.   Where can I download afterimage?
> > http://www.afterstep.org/afterimage/
> > Also, in general, if I want to add a configure to petsc with
> ./configure, do I have to run ./configure with ALL my options, or just with
> the new ones I want to add/change?  Will it save my previous configure?
> > Run $PETSC_ARCH/conf/reconfigure-*.py --new-options
> >  Thanks again for your rapid responses!
> >  - Ron C
> > On Tue, Jul 31, 2012 at 3:23 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> >   Sorry the postscript never really worked and then the world went PDF.
> >   You can do what you want in PETSc 3.3 with
> >     ierr = PetscOptionsBool("-draw_save_movie","Make a movie from the
> images saved","PetscDrawSetSave",movie,&movie,PETSC_NULL);CHKERRQ(ierr);
> >     ierr = PetscOptionsString("-draw_save","Save graphics to
> file","PetscDrawSetSave",filename,filename,PETSC_MAX_PATH_LEN,&save);CHKERRQ(ierr);
> > /*@C
> >    PetscDrawSave - Saves images produced in a PetscDraw into a file as a
> Gif file using AfterImage
> >    Collective on PetscDraw
> >    Input Parameter:
> > +  draw      - the graphics context
> > .  filename  - name of the file, if PETSC_NULL uses name of draw object
> > -  movie - produce a movie of all the images
> >    Options Database Command:
> > +  -draw_save  <filename>
> > -  -draw_save_movie
> >    Level: intermediate
> >    Concepts: X windows^graphics
> >    Concepts: drawing^postscript
> >    Concepts: postscript^graphics
> >    Concepts: drawing^Microsoft Windows
> >    Notes: Requires that PETSc be configured with the option
> --with-afterimage
> > .seealso: PetscDrawSetFromOptions(), PetscDrawCreate(),
> PetscDrawDestroy(), PetscDrawSave()
> >   Please report any problems to petsc-maint at mcs.anl.gov
> >   Note that you must make sure the windows being saved are not covered
> by other windows.
> >    Barry
> > On Jul 31, 2012, at 3:17 PM, "Ronald M. Caplan" <caplanr at predsci.com>
> wrote:
> > > Hi,
> > > I saw online that back in 2006 there was a way to tell PETSc to save
> the image in -mat_view_draw into a postscript file.  Is there anyway to
> still do this?  Or to same the image into any format?  Or to save a movie
> of the residual images in ksp?
> > > Thanks,
> > > Ron C.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120801/b520e1e2/attachment.html>
