[petsc-users] Save matrix view to postscript?
Ronald M. Caplan caplanr at predsci.com
Wed Aug 1 12:07:52 CDT 2012
After configuring with --with-afterimage I now cannot even get eh x-windows
to show the matrix at all.  I get the following error:
X Error of failed request:  BadValue (integer parameter out of range for
operation)
  Major opcode of failed request:  1 (X_CreateWindow)
  Value in failed request:  0xae
  Serial number of failed request:  7
  Current serial number in output stream:  14
 - Ron
On Tue, Jul 31, 2012 at 4:20 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Tue, Jul 31, 2012 at 4:13 PM, Ronald M. Caplan <caplanr at predsci.com>wrote:
>> Thanks!
>> I can't seem to get it to work though.
>> When I configure --with-afterimage it says that I need to download it.
>> When I use --download-afterimage it says:
>> "External package afterimage does not support --download-afterimage"
>> I am using a MAC with OS X.   Where can I download afterimage?
> http://www.afterstep.org/afterimage/
>> Also, in general, if I want to add a configure to petsc with ./configure,
>> do I have to run ./configure with ALL my options, or just with the new ones
>> I want to add/change?  Will it save my previous configure?
> Run $PETSC_ARCH/conf/reconfigure-*.py --new-options
>>  Thanks again for your rapid responses!
>>  - Ron C
>> On Tue, Jul 31, 2012 at 3:23 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>>   Sorry the postscript never really worked and then the world went PDF.
>>>   You can do what you want in PETSc 3.3 with
>>>     ierr = PetscOptionsBool("-draw_save_movie","Make a movie from the
>>> images saved","PetscDrawSetSave",movie,&movie,PETSC_NULL);CHKERRQ(ierr);
>>>     ierr = PetscOptionsString("-draw_save","Save graphics to
>>> file","PetscDrawSetSave",filename,filename,PETSC_MAX_PATH_LEN,&save);CHKERRQ(ierr);
>>> /*@C
>>>    PetscDrawSave - Saves images produced in a PetscDraw into a file as a
>>> Gif file using AfterImage
>>>    Collective on PetscDraw
>>>    Input Parameter:
>>> +  draw      - the graphics context
>>> .  filename  - name of the file, if PETSC_NULL uses name of draw object
>>> -  movie - produce a movie of all the images
>>>    Options Database Command:
>>> +  -draw_save  <filename>
>>> -  -draw_save_movie
>>>    Level: intermediate
>>>    Concepts: X windows^graphics
>>>    Concepts: drawing^postscript
>>>    Concepts: postscript^graphics
>>>    Concepts: drawing^Microsoft Windows
>>>    Notes: Requires that PETSc be configured with the option
>>> --with-afterimage
>>> .seealso: PetscDrawSetFromOptions(), PetscDrawCreate(),
>>> PetscDrawDestroy(), PetscDrawSave()
>>>   Please report any problems to petsc-maint at mcs.anl.gov
>>>   Note that you must make sure the windows being saved are not covered
>>> by other windows.
>>>    Barry
>>> On Jul 31, 2012, at 3:17 PM, "Ronald M. Caplan" <caplanr at predsci.com>
>>> wrote:
>>> > Hi,
>>> > I saw online that back in 2006 there was a way to tell PETSc to save
>>> the image in -mat_view_draw into a postscript file.  Is there anyway to
>>> still do this?  Or to same the image into any format?  Or to save a movie
>>> of the residual images in ksp?
>>> > Thanks,
>>> > Ron C.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120801/96e6e7f8/attachment.html>
