[petsc-users] [petsc-3.2] MatView on dense matrix
Alexander Grayver agrayver at gfz-potsdam.de
Mon Sep 19 01:53:45 CDT 2011
Hello,
Is that possible to get fixed version?
Alexander
On 16.09.2011 19:59, Barry Smith wrote:
>     The problem is from the C values of these parameters have gotten out of sync with the Fortran values.
>      Satish,
>       Could you please fix the finclude/petscviewer.h values to match the C in petsc-3.2 and send a patch?
>       Thanks
>       Barry
> On Sep 16, 2011, at 5:38 AM, Alexander Grayver wrote:
>> Hello,
>> With petsc-3.1 I used this code to output MPI dense matrix:
>> PetscViewer          :: dviewer
>> call PetscViewerBinaryOpen(MPI_COMM_WORLD,'A.dat',FILE_MODE_WRITE,dviewer,ierr); CHKERRQ(ierr)
>> call PetscViewerSetFormat(dviewer,PETSC_VIEWER_NATIVE,ierr); CHKERRQ(ierr)
>> call MatView(A,dviewer,ierr); CHKERRQ(ierr)
>> call PetscViewerDestroy(dviewer,ierr); CHKERRQ(ierr)
>> With petsc-3.2 this code fails with error:
>> [7]PETSC ERROR: --------------------- Error Message ------------------------------------
>> [7]PETSC ERROR: No support for this operation for this object type!
>> [7]PETSC ERROR: To store a parallel dense matrix you must first call PetscViewerSetFormat(viewer,PETSC_VIEWER_NATIVE)!
>> [7]PETSC ERROR: ------------------------------------------------------------------------
>> [7]PETSC ERROR: Petsc Release Version 3.2.0, Patch 1, Mon Sep 12 16:01:51 CDT 2011
>> [7]PETSC ERROR: See docs/changes/index.html for recent updates.
>> [7]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>> [7]PETSC ERROR: See docs/index.html for manual pages.
>> [7]PETSC ERROR: /home/run/test on a openmpi-i named node205 by user Fri Sep 16 09:17:13 2011
>> [7]PETSC ERROR: Libraries linked from /home/lib/petsc-3.2-p1/openmpi-intel-complex-debug-f/lib
>> [7]PETSC ERROR: Configure run at Wed Sep 14 14:32:55 2011
>> [7]PETSC ERROR: Configure options --with-petsc-arch=openmpi-intel-complex-debug-f --with-fortran-interfaces=1 --with-mpi-dir=/opt/mpi/intel/openmpi-1.4.2 --with-scalar-type=complex --with-blas-lapack-dir=/opt/intel/Compiler/11.1/072/mkl/lib/em64t --with-precision=double --with-x=0
>> [7]PETSC ERROR: MatView_MPIDense_Binary() line 667 in /home/lib/petsc-3.2-p1/src/mat/impls/dense/mpi/mpidense.c
>> [7]PETSC ERROR: MatView_MPIDense() line 789 in /home/lib/petsc-3.2-p1/src/mat/impls/dense/mpi/mpidense.c
>> [7]PETSC ERROR: MatView() line 757 in /home/lib/petsc-3.2-p1/src/mat/interface/matrix.c
>> See full error attached. Is there something new in petsc-3.2 concerning matrix output?
>> Regards,
>> Alexander
>> <error.txt>
