[petsc-users] [petsc-3.2] MatView on dense matrix
    Satish Balay
    balay at mcs.anl.gov
    Mon Sep 19 22:16:04 CDT 2011
Can you try the attached patch - and see if it fixes the problem?
cd petsc-3.2-p2
patch -Np1 < viewer-f.patch
Satish
On Mon, 19 Sep 2011, Alexander Grayver wrote:
> Hello,
> Is that possible to get fixed version?
> Regards,
> Alexander
> On 16.09.2011 19:59, Barry Smith wrote:
> >     The problem is from the C values of these parameters have gotten out of
> > sync with the Fortran values.
> >      Satish,
> >       Could you please fix the finclude/petscviewer.h values to match the C
> > in petsc-3.2 and send a patch?
> >       Thanks
> >       Barry
> > On Sep 16, 2011, at 5:38 AM, Alexander Grayver wrote:
> > > Hello,
> > > With petsc-3.1 I used this code to output MPI dense matrix:
> > > PetscViewer          :: dviewer
> > > call
> > > PetscViewerBinaryOpen(MPI_COMM_WORLD,'A.dat',FILE_MODE_WRITE,dviewer,ierr);
> > > CHKERRQ(ierr)
> > > call PetscViewerSetFormat(dviewer,PETSC_VIEWER_NATIVE,ierr); CHKERRQ(ierr)
> > > call MatView(A,dviewer,ierr); CHKERRQ(ierr)
> > > call PetscViewerDestroy(dviewer,ierr); CHKERRQ(ierr)
> > > With petsc-3.2 this code fails with error:
> > > [7]PETSC ERROR: --------------------- Error Message
> > > [7]PETSC ERROR: No support for this operation for this object type!
> > > [7]PETSC ERROR: To store a parallel dense matrix you must first call
> > > PetscViewerSetFormat(viewer,PETSC_VIEWER_NATIVE)!
> > > [7]PETSC ERROR:
> > > [7]PETSC ERROR: Petsc Release Version 3.2.0, Patch 1, Mon Sep 12 16:01:51
> > > CDT 2011
> > > [7]PETSC ERROR: See docs/changes/index.html for recent updates.
> > > [7]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> > > [7]PETSC ERROR: See docs/index.html for manual pages.
> > > [7]PETSC ERROR:
> > > [7]PETSC ERROR: /home/run/test on a openmpi-i named node205 by user Fri
> > > Sep 16 09:17:13 2011
> > > [7]PETSC ERROR: Libraries linked from
> > > /home/lib/petsc-3.2-p1/openmpi-intel-complex-debug-f/lib
> > > [7]PETSC ERROR: Configure run at Wed Sep 14 14:32:55 2011
> > > [7]PETSC ERROR: Configure options
> > > --with-petsc-arch=openmpi-intel-complex-debug-f
> > > --with-fortran-interfaces=1 --with-mpi-dir=/opt/mpi/intel/openmpi-1.4.2
> > > --with-scalar-type=complex
> > > --with-blas-lapack-dir=/opt/intel/Compiler/11.1/072/mkl/lib/em64t
> > > --with-precision=double --with-x=0
> > > [7]PETSC ERROR:
> > > [7]PETSC ERROR: MatView_MPIDense_Binary() line 667 in
> > > /home/lib/petsc-3.2-p1/src/mat/impls/dense/mpi/mpidense.c
> > > [7]PETSC ERROR: MatView_MPIDense() line 789 in
> > > [7]PETSC ERROR: MatView() line 757 in
> > > /home/lib/petsc-3.2-p1/src/mat/interface/matrix.c
> > > See full error attached. Is there something new in petsc-3.2 concerning
> > > matrix output?
> > > Regards,
> > > Alexander
> > > <error.txt>
diff -r 143491d19702 include/finclude/petscviewer.h
--- a/include/finclude/petscviewer.h	Mon Sep 19 15:07:17 2011 -0500
+++ b/include/finclude/petscviewer.h	Mon Sep 19 22:14:41 2011 -0500
@@ -30,7 +30,7 @@
       PetscEnum PETSC_VIEWER_ASCII_MATHEMATICA
       PetscEnum PETSC_VIEWER_ASCII_IMPL
       PetscEnum PETSC_VIEWER_ASCII_INFO
-      PetscEnum PETSC_VIEWER_ASCII_INFO_DETAIL
+      PetscEnum PETSC_VIEWER_ASCII_INFO_DETAIL
       PetscEnum PETSC_VIEWER_ASCII_COMMON
       PetscEnum PETSC_VIEWER_ASCII_SYMMODU
       PetscEnum PETSC_VIEWER_ASCII_INDEX
@@ -40,10 +40,14 @@
       PetscEnum PETSC_VIEWER_ASCII_VTK_CELL
       PetscEnum PETSC_VIEWER_ASCII_VTK_COORDS
       PetscEnum PETSC_VIEWER_ASCII_PCICE
-      PetscEnum PETSC_VIEWER_ASCII_PYLITH
-      PetscEnum PETSC_VIEWER_ASCII_PYLITH_LOCAL
       PetscEnum PETSC_VIEWER_ASCII_PYTHON
       PetscEnum PETSC_VIEWER_ASCII_FACTOR_INFO
+      PetscEnum PETSC_VIEWER_DRAW_BASIC
+      PetscEnum PETSC_VIEWER_DRAW_LG
+      PetscEnum PETSC_VIEWER_DRAW_CONTOUR
+      PetscEnum PETSC_VIEWER_DRAW_PORTS
+      PetscEnum PETSC_VIEWER_NATIVE
+      PetscEnum PETSC_VIEWER_NOFORMAT
       parameter (PETSC_VIEWER_DEFAULT = 0)
       parameter (PETSC_VIEWER_ASCII_MATLAB = 1)
@@ -60,24 +64,14 @@
       parameter (PETSC_VIEWER_ASCII_VTK_CELL = 12)
       parameter (PETSC_VIEWER_ASCII_VTK_COORDS = 13)
       parameter (PETSC_VIEWER_ASCII_PCICE = 14)
-      parameter (PETSC_VIEWER_ASCII_PYLITH = 15)
-      parameter (PETSC_VIEWER_ASCII_PYLITH_LOCAL = 16)
-      parameter (PETSC_VIEWER_ASCII_PYTHON = 17)
-      parameter (PETSC_VIEWER_ASCII_FACTOR_INFO = 18)
-      PetscEnum PETSC_VIEWER_DRAW_BASIC
-      PetscEnum PETSC_VIEWER_DRAW_LG
-      PetscEnum PETSC_VIEWER_DRAW_CONTOUR
-      PetscEnum PETSC_VIEWER_DRAW_PORTS
-      parameter (PETSC_VIEWER_DRAW_BASIC = 19)
-      parameter (PETSC_VIEWER_DRAW_LG = 20)
-      parameter (PETSC_VIEWER_DRAW_CONTOUR = 21)
-      parameter (PETSC_VIEWER_DRAW_PORTS = 22)
-      PetscEnum PETSC_VIEWER_NATIVE
-      parameter (PETSC_VIEWER_NATIVE = 23)
-      PetscEnum PETSC_VIEWER_NOFORMAT
-      parameter (PETSC_VIEWER_NOFORMAT = 24)
+      parameter (PETSC_VIEWER_ASCII_PYTHON = 15)
+      parameter (PETSC_VIEWER_ASCII_FACTOR_INFO = 16)
+      parameter (PETSC_VIEWER_DRAW_BASIC = 17)
+      parameter (PETSC_VIEWER_DRAW_LG = 18)
+      parameter (PETSC_VIEWER_DRAW_CONTOUR = 19)
+      parameter (PETSC_VIEWER_DRAW_PORTS = 20)
+      parameter (PETSC_VIEWER_NATIVE = 21)
+      parameter (PETSC_VIEWER_NOFORMAT = 22)
 !  End of Fortran include file for the PetscViewer package in PETSc
diff -r 143491d19702 include/finclude/petscviewerdef.h
--- a/include/finclude/petscviewerdef.h	Mon Sep 19 15:07:17 2011 -0500
+++ b/include/finclude/petscviewerdef.h	Mon Sep 19 22:14:41 2011 -0500
@@ -18,9 +18,11 @@
 #define PETSCVIEWERBINARY 'binary'
 #define PETSCVIEWERSTRING 'string'
 #define PETSCVIEWERDRAW 'draw'
+#define PETSCVIEWERVU 'vu'
+#define PETSCVIEWERMATHEMATICA 'mathematica'
+#define PETSCVIEWERNETCDF 'netcdf'
+#define PETSCVIEWERHDF5 'hdf5'
+#define PETSCVIEWERMATLAB 'matlab'
 #define PETSCVIEWERAMS 'ams'
-#define PETSCVIEWERHDF5 'hdf5'
-#define PETSCVIEWERNETCDF 'netcdf'
-#define PETSCVIEWERMATLAB 'matlab'
 #endif
