[petsc-users] [petsc-3.2] MatView on dense matrix
Fri Sep 16 12:59:24 CDT 2011
   The problem is from the C values of these parameters have gotten out of sync with the Fortran values.
    Satish,
     Could you please fix the finclude/petscviewer.h values to match the C in petsc-3.2 and send a patch?
     Thanks
     Barry
On Sep 16, 2011, at 5:38 AM, Alexander Grayver wrote:
> Hello,
> With petsc-3.1 I used this code to output MPI dense matrix:
> PetscViewer          :: dviewer
> call PetscViewerBinaryOpen(MPI_COMM_WORLD,'A.dat',FILE_MODE_WRITE,dviewer,ierr); CHKERRQ(ierr)
> call PetscViewerSetFormat(dviewer,PETSC_VIEWER_NATIVE,ierr); CHKERRQ(ierr)
> call MatView(A,dviewer,ierr); CHKERRQ(ierr)
> call PetscViewerDestroy(dviewer,ierr); CHKERRQ(ierr)
> With petsc-3.2 this code fails with error:
> [7]PETSC ERROR: --------------------- Error Message ------------------------------------
> [7]PETSC ERROR: No support for this operation for this object type!
> [7]PETSC ERROR: To store a parallel dense matrix you must first call PetscViewerSetFormat(viewer,PETSC_VIEWER_NATIVE)!
> [7]PETSC ERROR: ------------------------------------------------------------------------
> [7]PETSC ERROR: Petsc Release Version 3.2.0, Patch 1, Mon Sep 12 16:01:51 CDT 2011
> [7]PETSC ERROR: See docs/changes/index.html for recent updates.
> [7]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [7]PETSC ERROR: See docs/index.html for manual pages.
> [7]PETSC ERROR: /home/run/test on a openmpi-i named node205 by user Fri Sep 16 09:17:13 2011
> [7]PETSC ERROR: Libraries linked from /home/lib/petsc-3.2-p1/openmpi-intel-complex-debug-f/lib
> [7]PETSC ERROR: Configure run at Wed Sep 14 14:32:55 2011
> [7]PETSC ERROR: Configure options --with-petsc-arch=openmpi-intel-complex-debug-f --with-fortran-interfaces=1 --with-mpi-dir=/opt/mpi/intel/openmpi-1.4.2 --with-scalar-type=complex --with-blas-lapack-dir=/opt/intel/Compiler/11.1/072/mkl/lib/em64t --with-precision=double --with-x=0
> [7]PETSC ERROR: MatView_MPIDense_Binary() line 667 in /home/lib/petsc-3.2-p1/src/mat/impls/dense/mpi/mpidense.c
> [7]PETSC ERROR: MatView_MPIDense() line 789 in /home/lib/petsc-3.2-p1/src/mat/impls/dense/mpi/mpidense.c
> [7]PETSC ERROR: MatView() line 757 in /home/lib/petsc-3.2-p1/src/mat/interface/matrix.c
> See full error attached. Is there something new in petsc-3.2 concerning matrix output?
> Regards,
> Alexander
> <error.txt>
