[petsc-users] [petsc-3.2] MatView on dense matrix
Matthew Knepley
knepley at gmail.com
Fri Sep 16 08:04:11 CDT 2011
On Fri, Sep 16, 2011 at 5:38 AM, Alexander Grayver
<agrayver at gfz-potsdam.de>wrote:
> Hello,
> With petsc-3.1 I used this code to output MPI dense matrix:
> PetscViewer :: dviewer
> call PetscViewerBinaryOpen(MPI_**COMM_WORLD,'A.dat',FILE_MODE_**WRITE,dviewer,ierr);
> CHKERRQ(ierr)
> call PetscViewerSetFormat(dviewer,**PETSC_VIEWER_NATIVE,ierr);
> CHKERRQ(ierr)
> call MatView(A,dviewer,ierr); CHKERRQ(ierr)
> call PetscViewerDestroy(dviewer,**ierr); CHKERRQ(ierr)
> With petsc-3.2 this code fails with error:
This error just says that the viewer did not return a format of
PETSC_VIEWER_NATIVE. Either you
accidentally set it in the wrong viewer, or not on every process, or there
is memory corruption. I recommend
using the debugger to see what format is returned.
Matt
> [7]PETSC ERROR: --------------------- Error Message
> [7]PETSC ERROR: No support for this operation for this object type!
> [7]PETSC ERROR: To store a parallel dense matrix you must first call
> PetscViewerSetFormat(viewer,**PETSC_VIEWER_NATIVE)!
> [7]PETSC ERROR: ------------------------------**
> [7]PETSC ERROR: Petsc Release Version 3.2.0, Patch 1, Mon Sep 12 16:01:51
> CDT 2011
> [7]PETSC ERROR: See docs/changes/index.html for recent updates.
> [7]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [7]PETSC ERROR: See docs/index.html for manual pages.
> [7]PETSC ERROR: /home/run/test on a openmpi-i named node205 by user Fri Sep
> 16 09:17:13 2011
> [7]PETSC ERROR: Libraries linked from /home/lib/petsc-3.2-p1/**
> openmpi-intel-complex-debug-f/**lib
> [7]PETSC ERROR: Configure run at Wed Sep 14 14:32:55 2011
> [7]PETSC ERROR: Configure options --with-petsc-arch=openmpi-**intel-complex-debug-f
> --with-fortran-interfaces=1 --with-mpi-dir=/opt/mpi/intel/**openmpi-1.4.2
> --with-scalar-type=complex --with-blas-lapack-dir=/opt/**
> intel/Compiler/11.1/072/mkl/**lib/em64t --with-precision=double --with-x=0
> [7]PETSC ERROR: MatView_MPIDense_Binary() line 667 in
> /home/lib/petsc-3.2-p1/src/**mat/impls/dense/mpi/mpidense.c
> [7]PETSC ERROR: MatView_MPIDense() line 789 in /home/lib/petsc-3.2-p1/src/
> [7]PETSC ERROR: MatView() line 757 in /home/lib/petsc-3.2-p1/src/**
> mat/interface/matrix.c
> MatView_MPIDense() line 789 in /home/lib/petsc-3.2-p1/src/**
> See full error attached. Is there something new in petsc-3.2 concerning
> matrix output?
> Regards,
> Alexander
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110916/cd5f41d0/attachment-0001.htm>
