[petsc-users] [petsc-3.2] MatView on dense matrix
Alexander Grayver agrayver at gfz-potsdam.de
Fri Sep 16 05:38:53 CDT 2011
Hello,
With petsc-3.1 I used this code to output MPI dense matrix:
PetscViewer          :: dviewer
call
PetscViewerBinaryOpen(MPI_COMM_WORLD,'A.dat',FILE_MODE_WRITE,dviewer,ierr);
CHKERRQ(ierr)
call PetscViewerSetFormat(dviewer,PETSC_VIEWER_NATIVE,ierr); CHKERRQ(ierr)
call MatView(A,dviewer,ierr); CHKERRQ(ierr)
call PetscViewerDestroy(dviewer,ierr); CHKERRQ(ierr)
With petsc-3.2 this code fails with error:
[7]PETSC ERROR: --------------------- Error Message
[7]PETSC ERROR: No support for this operation for this object type!
[7]PETSC ERROR: To store a parallel dense matrix you must first call
PetscViewerSetFormat(viewer,PETSC_VIEWER_NATIVE)!
[7]PETSC ERROR:
[7]PETSC ERROR: Petsc Release Version 3.2.0, Patch 1, Mon Sep 12
16:01:51 CDT 2011
[7]PETSC ERROR: See docs/changes/index.html for recent updates.
[7]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[7]PETSC ERROR: See docs/index.html for manual pages.
[7]PETSC ERROR:
[7]PETSC ERROR: /home/run/test on a openmpi-i named node205 by user Fri
Sep 16 09:17:13 2011
[7]PETSC ERROR: Libraries linked from
/home/lib/petsc-3.2-p1/openmpi-intel-complex-debug-f/lib
[7]PETSC ERROR: Configure run at Wed Sep 14 14:32:55 2011
[7]PETSC ERROR: Configure options
--with-petsc-arch=openmpi-intel-complex-debug-f
--with-fortran-interfaces=1 --with-mpi-dir=/opt/mpi/intel/openmpi-1.4.2
--with-scalar-type=complex
--with-blas-lapack-dir=/opt/intel/Compiler/11.1/072/mkl/lib/em64t
--with-precision=double --with-x=0
[7]PETSC ERROR:
[7]PETSC ERROR: MatView_MPIDense_Binary() line 667 in
/home/lib/petsc-3.2-p1/src/mat/impls/dense/mpi/mpidense.c
[7]PETSC ERROR: MatView_MPIDense() line 789 in
[7]PETSC ERROR: MatView() line 757 in
/home/lib/petsc-3.2-p1/src/mat/interface/matrix.c
See full error attached. Is there something new in petsc-3.2 concerning
matrix output?
Alexander
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110916/be2cf621/attachment-0001.txt>
