[petsc-users] [petsc-3.2] MatView on dense matrix
    Alexander Grayver
    agrayver at gfz-potsdam.de
    Fri Sep 16 12:15:16 CDT 2011
Matt,
Can you explain what do you by seeing what format is returned?
I will check in debugger of course, but still I find it strange.
I have two versions of petsc (3.1-p7 and 3.2-p1) configured with the
same options, my code and runs are absolutely identical and I get this
error only with petsc-3.2.
Alexander
On 16.09.2011 15:04, Matthew Knepley wrote:
> On Fri, Sep 16, 2011 at 5:38 AM, Alexander Grayver
> <agrayver at gfz-potsdam.de <mailto:agrayver at gfz-potsdam.de>> wrote:
>     Hello,
>     With petsc-3.1 I used this code to output MPI dense matrix:
>     PetscViewer          :: dviewer
>     call
>     PetscViewerBinaryOpen(MPI_COMM_WORLD,'A.dat',FILE_MODE_WRITE,dviewer,ierr);
>     CHKERRQ(ierr)
>     call PetscViewerSetFormat(dviewer,PETSC_VIEWER_NATIVE,ierr);
>     CHKERRQ(ierr)
>     call MatView(A,dviewer,ierr); CHKERRQ(ierr)
>     call PetscViewerDestroy(dviewer,ierr); CHKERRQ(ierr)
>     With petsc-3.2 this code fails with error:
> This error just says that the viewer did not return a format of
> PETSC_VIEWER_NATIVE. Either you
> accidentally set it in the wrong viewer, or not on every process, or
> there is memory corruption. I recommend
> using the debugger to see what format is returned.
>   Thanks,
>      Matt
>     [7]PETSC ERROR: --------------------- Error Message
>     [7]PETSC ERROR: No support for this operation for this object type!
>     [7]PETSC ERROR: To store a parallel dense matrix you must first
>     call PetscViewerSetFormat(viewer,PETSC_VIEWER_NATIVE)!
>     [7]PETSC ERROR:
>     [7]PETSC ERROR: Petsc Release Version 3.2.0, Patch 1, Mon Sep 12
>     16:01:51 CDT 2011
>     [7]PETSC ERROR: See docs/changes/index.html for recent updates.
>     [7]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>     [7]PETSC ERROR: See docs/index.html for manual pages.
>     [7]PETSC ERROR:
>     [7]PETSC ERROR: /home/run/test on a openmpi-i named node205 by
>     user Fri Sep 16 09:17:13 2011
>     [7]PETSC ERROR: Libraries linked from
>     /home/lib/petsc-3.2-p1/openmpi-intel-complex-debug-f/lib
>     [7]PETSC ERROR: Configure run at Wed Sep 14 14:32:55 2011
>     [7]PETSC ERROR: Configure options
>     --with-petsc-arch=openmpi-intel-complex-debug-f
>     --with-fortran-interfaces=1
>     --with-mpi-dir=/opt/mpi/intel/openmpi-1.4.2
>     --with-scalar-type=complex
>     --with-blas-lapack-dir=/opt/intel/Compiler/11.1/072/mkl/lib/em64t
>     --with-precision=double --with-x=0
>     [7]PETSC ERROR:
>     [7]PETSC ERROR: MatView_MPIDense_Binary() line 667 in
>     /home/lib/petsc-3.2-p1/src/mat/impls/dense/mpi/mpidense.c
>     [7]PETSC ERROR: MatView_MPIDense() line 789 in
>     [7]PETSC ERROR: MatView() line 757 in
>     /home/lib/petsc-3.2-p1/src/mat/interface/matrix.c
>     See full error attached. Is there something new in petsc-3.2
>     concerning matrix output?
>     Regards,
>     Alexander
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110916/693e4beb/attachment.htm>
