[petsc-users] Problems with last PETSC-3.2 release on Windows
Satish Balay
balay at mcs.anl.gov
Thu Sep 15 09:48:17 CDT 2011
I just ran petsc-32 with ifort - and it ran fine. So I'm not sure
whats hapenning in this case..
Is this error reproduceable [if configure is rerun with the same options?]
Satish
Intel(R) Visual Fortran Compiler for applications running on Intel(R) 64, Version 10.1 Build 20080212 Package ID: w_fc_p_10.1.019
TEST checkFortranModuleInclude from config.compilers(/home/balay/petsc-3.2/config/BuildSystem/config/compilers.py:1155)
TESTING: checkFortranModuleInclude from config.compilers(config/BuildSystem/config/compilers.py:1155)
Figures out what flag is used to specify the include path for Fortran modules
Pushing language FC
sh: /home/balay/petsc-3.2/bin/win32fe/win32fe ifort -c -o /tmp/petsc-zRoAJW/config.compilers/conftest.o -I/tmp/petsc-zRoAJW/config.compilers -I/tmp/petsc-zRoAJW/config.setCompilers -MT -Z7 -fpp /tmp/petsc-zRoAJW/config.compilers/conftest.F
Executing: /home/balay/petsc-3.2/bin/win32fe/win32fe ifort -c -o /tmp/petsc-zRoAJW/config.compilers/conftest.o -I/tmp/petsc-zRoAJW/config.compilers -I/tmp/petsc-zRoAJW/config.setCompilers -MT -Z7 -fpp /tmp/petsc-zRoAJW/config.compilers/conftest.F
sh:
Successful compile:
Source:
module configtest
integer testint
parameter (testint = 42)
end module configtest
Pushing language FC
sh: /home/balay/petsc-3.2/bin/win32fe/win32fe ifort -c -o /tmp/petsc-zRoAJW/config.compilers/conftest.o -I/tmp/petsc-zRoAJW/config.compilers -I/tmp/petsc-zRoAJW/config.setCompilers -I/tmp/petsc-zRoAJW/config.compilers/confdir -MT -Z7 -fpp /tmp/petsc-zRoAJW/config.compilers/conftest.F
Executing: /home/balay/petsc-3.2/bin/win32fe/win32fe ifort -c -o /tmp/petsc-zRoAJW/config.compilers/conftest.o -I/tmp/petsc-zRoAJW/config.compilers -I/tmp/petsc-zRoAJW/config.setCompilers -I/tmp/petsc-zRoAJW/config.compilers/confdir -MT -Z7 -fpp /tmp/petsc-zRoAJW/config.compilers/conftest.F
sh:
Successful compile:
Source:
program main
use configtest
write(*,*) testint
end
Pushing language FC
Popping language FC
sh: /home/balay/petsc-3.2/bin/win32fe/win32fe ifort -o /tmp/petsc-zRoAJW/config.compilers/conftest.exe -I/tmp/petsc-zRoAJW/config.compilers/confdir -MT -Z7 -fpp /tmp/petsc-zRoAJW/config.compilers/conftest.o /tmp/petsc-zRoAJW/config.compilers/configtest.o
Executing: /home/balay/petsc-3.2/bin/win32fe/win32fe ifort -o /tmp/petsc-zRoAJW/config.compilers/conftest.exe -I/tmp/petsc-zRoAJW/config.compilers/confdir -MT -Z7 -fpp /tmp/petsc-zRoAJW/config.compilers/conftest.o /tmp/petsc-zRoAJW/config.compilers/configtest.o
sh: LINK : C:\cygwin\tmp\PETSC-~3\CONFIG~1.COM\conftest.exe not found or not built by the last incremental link; performing full link^M
compilers: Fortran module include flag -I found
Popping language FC
On Thu, 15 Sep 2011, Matthew Knepley wrote:
> On Thu, Sep 15, 2011 at 8:43 AM, Alexander Grayver
> <agrayver at gfz-potsdam.de>wrote:
> > Thanks Matt,
> > I will that, but I use PETSC from Fortran so I need Fortran functionality.
> Sure. Do you use the F90 modules? If so, send us the build problem. If there
> is not build problem,
> then ifort supports only relative paths for module includes, which is crazy
> and will break sometimes.
> Thanks,
> Matt
> > Regards,
> > Alexander
> > On 15.09.2011 15:43, Matthew Knepley wrote:
> > On Thu, Sep 15, 2011 at 8:01 AM, Alexander Grayver <
> > agrayver at gfz-potsdam.de> wrote:
> >> Matthew,
> >> I found this check in configure.log I obtained for petsc-3.1-p7:
> >> config.compilers(/cygdrive/d/Dev/petsc-3.1-p7/config/BuildSystem/config/compilers.py:1084)
> >> config.compilers(config/BuildSystem/config/compilers.py:1084)
> >> modules
> >> Pushing language FC
> >> sh: /cygdrive/d/Dev/petsc-3.1-p7/bin/win32fe/win32fe ifort -c -o
> >> conftest.o -MT -Z7 -fpp conftest.F
> >> Executing: /cygdrive/d/Dev/petsc-3.1-p7/bin/win32fe/win32fe ifort -c -o
> >> sh:
> >> Pushing language FC
> >> conftest.o -Iconfdir -MT -Z7 -fpp conftest.F
> >> sh:
> >> Pushing language FC
> >> Popping language FC
> >> sh: /cygdrive/d/Dev/petsc-3.1-p7/bin/win32fe/win32fe ifort -o
> >> conftest.exe -Iconfdir -MT -Z7 -fpp conftest.o configtest.o
> >> Executing: /cygdrive/d/Dev/petsc-3.1-p7/bin/win32fe/win32fe ifort -o
> >> sh: LINK : D:\Dev\PETSC-~2.1-P\conftest.exe not found or not built by the
> >> Popping language FC
> >> The compiler I used is the same I use for petsc-3.2-p1.
> >> The difference is in the paths where you try to build this tests. As far
> >> as I understand for petsc-3.1-p7 you used local directory and for
> >> petsc-3.2-p1 temp directory is used.
> >> Could it be the reason?
> > That would be broken behavior from ifort, but I guess it is possible. I
> > will talk with Satish about how
> > this should really be fixed. For right now, go to
> > to the checkFortranModuleInclude() function and comment out the last two
> > lines, which are killing the configure.
> > Your build will break on the Fortran modules (I assume), but everything
> > else should work.
> > Thanks,
> > Matt
> >> Regards,
> >> Alexander
> >> On 15.09.2011 14:54, Matthew Knepley wrote:
> >> On Thu, Sep 15, 2011 at 2:49 AM, Alexander Grayver <
> >>> Hello,
> >>> I hope you are having nice day!
> >>> I have been using petsc-3.1-p7 under windows for 6 months and now decided
> >>> to get new version. I used my old configure line which was successful for
> >>> petsc-3.1:
> >>> ./config/configure.py --PETSC_DIR=/cygdrive/d/dev/petsc-3.2-p1
> >>> --with-petsc-arch=cygwin-cxx-debug-fortran --with-fortran-interfaces=1
> >>> --with-cc='win32fe cl' --with-fc='win32fe ifort' --with-cxx='win32fe cl'
> >>> --with-windows-graphics=0 --download-f-blas-lapack=1 --with-precision=double
> >>> --with-scalar-type=complex --with-clanguage=cxx
> >>> --with-mpi-include="/cygdrive/d/Dev/HPC_2008_SDK/Include"
> >>> --with-mpi-lib=["/cygdrive/d/Dev/HPC_2008_SDK/Lib/amd64/msmpi.lib","/cygdrive/d/Dev/HPC_2008_SDK/Lib/amd64/msmpifec.lib"]
> >>> --useThreads=0
> >>> But unfortunately it doesn't work properly anymore, even though my
> >>> development environment has not been changed. The error is:
> >>> UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for
> >>> details):
> >>> Cannot determine Fortran module include flag
> >>> Please find configure.log attached.
> >> The problem here is that your Fortran compiler reports that is supports
> >> F90, but cannot
> >> locate modules using an include path. This will make parts of the PETSc
> >> build fail. Do you
> >> know what flag it uses? I try -I, -p, and -M.
> >> Thanks,
> >> Matt
> >>> Regards,
> >>> Alexander
> >> What most experimenters take for granted before they begin their
> >> experiments is infinitely more interesting than any results to which their
> >> experiments lead.
> >> -- Norbert Wiener
> > experiments lead.
> > -- Norbert Wiener
