[petsc-users] Problems with last PETSC-3.2 release on Windows
Thu Sep 15 08:49:54 CDT 2011
On Thu, Sep 15, 2011 at 8:43 AM, Alexander Grayver
<agrayver at gfz-potsdam.de>wrote:
> Thanks Matt,
> I will that, but I use PETSC from Fortran so I need Fortran functionality.
Sure. Do you use the F90 modules? If so, send us the build problem. If there
is not build problem,
then ifort supports only relative paths for module includes, which is crazy
and will break sometimes.
     Matt
> Regards,
> Alexander
> On 15.09.2011 15:43, Matthew Knepley wrote:
> On Thu, Sep 15, 2011 at 8:01 AM, Alexander Grayver <
> agrayver at gfz-potsdam.de> wrote:
>>  Matthew,
>> I found this check in configure.log I obtained for petsc-3.1-p7:
>> TEST checkFortranModuleInclude from
>> config.compilers(/cygdrive/d/Dev/petsc-3.1-p7/config/BuildSystem/config/compilers.py:1084)
>> TESTING: checkFortranModuleInclude from
>> config.compilers(config/BuildSystem/config/compilers.py:1084)
>>   Figures out what flag is used to specify the include path for Fortran
>> modules
>>         Pushing language FC
>> sh: /cygdrive/d/Dev/petsc-3.1-p7/bin/win32fe/win32fe ifort -c -o
>> conftest.o  -MT -Z7 -fpp  conftest.F
>> Executing: /cygdrive/d/Dev/petsc-3.1-p7/bin/win32fe/win32fe ifort -c -o
>> sh:
>>         Pushing language FC
>> conftest.o -Iconfdir  -MT -Z7 -fpp  conftest.F
>> sh:
>>                 Pushing language FC
>>                 Popping language FC
>> sh: /cygdrive/d/Dev/petsc-3.1-p7/bin/win32fe/win32fe ifort  -o
>> conftest.exe   -Iconfdir  -MT -Z7 -fpp  conftest.o configtest.o
>> Executing: /cygdrive/d/Dev/petsc-3.1-p7/bin/win32fe/win32fe ifort  -o
>> sh: LINK : D:\Dev\PETSC-~2.1-P\conftest.exe not found or not built by the
>> last incremental link; performing full link
>>       compilers: Fortran module include flag -I found
>>         Popping language FC
>> The compiler I used is the same I use for petsc-3.2-p1.
>> The difference is in the paths where you try to build this tests. As far
>> as I understand for petsc-3.1-p7 you used local directory and for
>> petsc-3.2-p1 temp directory is used.
>> Could it be the reason?
>  That would be broken behavior from ifort, but I guess it is possible. I
> will talk with Satish about how
> this should really be fixed. For right now, go to
>  to the checkFortranModuleInclude() function and comment out the last two
> lines, which are killing the configure.
> Your build will break on the Fortran modules (I assume), but everything
> else should work.
>    Thanks,
>        Matt
>>  Regards,
>>  Alexander
>> On 15.09.2011 14:54, Matthew Knepley wrote:
>> On Thu, Sep 15, 2011 at 2:49 AM, Alexander Grayver <
>>> Hello,
>>> I hope you are having nice day!
>>> I have been using petsc-3.1-p7 under windows for 6 months and now decided
>>> to get new version. I used my old configure line which was successful for
>>> petsc-3.1:
>>> ./config/configure.py --PETSC_DIR=/cygdrive/d/dev/petsc-3.2-p1
>>> --with-petsc-arch=cygwin-cxx-debug-fortran --with-fortran-interfaces=1
>>> --with-cc='win32fe cl' --with-fc='win32fe ifort'  --with-cxx='win32fe cl'
>>> --with-windows-graphics=0 --download-f-blas-lapack=1 --with-precision=double
>>> --with-scalar-type=complex --with-clanguage=cxx
>>> --with-mpi-include="/cygdrive/d/Dev/HPC_2008_SDK/Include"
>>> --with-mpi-lib=["/cygdrive/d/Dev/HPC_2008_SDK/Lib/amd64/msmpi.lib","/cygdrive/d/Dev/HPC_2008_SDK/Lib/amd64/msmpifec.lib"]
>>> --useThreads=0
>>> But unfortunately it doesn't work properly anymore, even though my
>>> development environment has not been changed. The error is:
>>>         UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for
>>> details):
>>> Cannot determine Fortran module include flag
>>> Please find configure.log attached.
>>  The problem here is that your Fortran compiler reports that is supports
>> F90, but cannot
>> locate modules using an include path. This will make parts of the PETSc
>> build fail. Do you
>> know what flag it uses? I try -I, -p, and -M.
>>    Thanks,
>>       Matt
>>> Regards,
>>>  Alexander
>> experiments lead.
>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110915/e9b630c1/attachment.htm>
