[petsc-users] Problems with last PETSC-3.2 release on Windows
Alexander Grayver agrayver at gfz-potsdam.de
Thu Sep 15 12:11:19 CDT 2011
Satish,
It is reproducible.
So that is the nasty error, I don't know where to look for solution.
Anyway, I commented these lines in compiler.py as Matt suggested:
     #if not found:
     #  raise RuntimeError('Cannot determine Fortran module include flag')
And configure fails further down, but I suspect that this new error is
also somehow linked to the relative paths (seen log attached). Can you
confirmthis?
Alexander
On 15.09.2011 16:48, Satish Balay wrote:
> I just ran petsc-32 with ifort - and it ran fine. So I'm not sure
> whats hapenning in this case..
> Is this error reproduceable [if configure is rerun with the same options?]
> Satish
> Intel(R) Visual Fortran Compiler for applications running on Intel(R) 64, Version 10.1    Build 20080212 Package ID: w_fc_p_10.1.019
> TEST checkFortranModuleInclude from config.compilers(/home/balay/petsc-3.2/config/BuildSystem/config/compilers.py:1155)
> TESTING: checkFortranModuleInclude from config.compilers(config/BuildSystem/config/compilers.py:1155)
>    Figures out what flag is used to specify the include path for Fortran modules
>            Pushing language FC
> sh: /home/balay/petsc-3.2/bin/win32fe/win32fe ifort -c -o /tmp/petsc-zRoAJW/config.compilers/conftest.o -I/tmp/petsc-zRoAJW/config.compilers -I/tmp/petsc-zRoAJW/config.setCompilers  -MT -Z7 -fpp  /tmp/petsc-zRoAJW/config.compilers/conftest.F
> Executing: /home/balay/petsc-3.2/bin/win32fe/win32fe ifort -c -o /tmp/petsc-zRoAJW/config.compilers/conftest.o -I/tmp/petsc-zRoAJW/config.compilers -I/tmp/petsc-zRoAJW/config.setCompilers  -MT -Z7 -fpp  /tmp/petsc-zRoAJW/config.compilers/conftest.F
> sh:
> Successful compile:
> Source:
>        module configtest
>        integer testint
>        parameter (testint = 42)
>        end module configtest
>            Pushing language FC
> sh: /home/balay/petsc-3.2/bin/win32fe/win32fe ifort -c -o /tmp/petsc-zRoAJW/config.compilers/conftest.o -I/tmp/petsc-zRoAJW/config.compilers -I/tmp/petsc-zRoAJW/config.setCompilers -I/tmp/petsc-zRoAJW/config.compilers/confdir  -MT -Z7 -fpp  /tmp/petsc-zRoAJW/config.compilers/conftest.F
> Executing: /home/balay/petsc-3.2/bin/win32fe/win32fe ifort -c -o /tmp/petsc-zRoAJW/config.compilers/conftest.o -I/tmp/petsc-zRoAJW/config.compilers -I/tmp/petsc-zRoAJW/config.setCompilers -I/tmp/petsc-zRoAJW/config.compilers/confdir  -MT -Z7 -fpp  /tmp/petsc-zRoAJW/config.compilers/conftest.F
> sh:
> Successful compile:
> Source:
>        program main
>        use configtest
>        write(*,*) testint
>        end
>                    Pushing language FC
>                    Popping language FC
> sh: /home/balay/petsc-3.2/bin/win32fe/win32fe ifort  -o /tmp/petsc-zRoAJW/config.compilers/conftest.exe   -I/tmp/petsc-zRoAJW/config.compilers/confdir  -MT -Z7 -fpp /tmp/petsc-zRoAJW/config.compilers/conftest.o /tmp/petsc-zRoAJW/config.compilers/configtest.o
> Executing: /home/balay/petsc-3.2/bin/win32fe/win32fe ifort  -o /tmp/petsc-zRoAJW/config.compilers/conftest.exe   -I/tmp/petsc-zRoAJW/config.compilers/confdir  -MT -Z7 -fpp /tmp/petsc-zRoAJW/config.compilers/conftest.o /tmp/petsc-zRoAJW/config.compilers/configtest.o
> sh: LINK : C:\cygwin\tmp\PETSC-~3\CONFIG~1.COM\conftest.exe not found or not built by the last incremental link; performing full link^M
>          compilers: Fortran module include flag -I found
>            Popping language FC
> On Thu, 15 Sep 2011, Matthew Knepley wrote:
>> On Thu, Sep 15, 2011 at 8:43 AM, Alexander Grayver
>> <agrayver at gfz-potsdam.de>wrote:
>>> Thanks Matt,
>>> I will that, but I use PETSC from Fortran so I need Fortran functionality.
>> Sure. Do you use the F90 modules? If so, send us the build problem. If there
>> is not build problem,
>> then ifort supports only relative paths for module includes, which is crazy
>> and will break sometimes.
>>    Thanks,
>>       Matt
>>> Regards,
>>> Alexander
>>> On 15.09.2011 15:43, Matthew Knepley wrote:
>>> On Thu, Sep 15, 2011 at 8:01 AM, Alexander Grayver<
>>> agrayver at gfz-potsdam.de>  wrote:
>>>>   Matthew,
>>>> I found this check in configure.log I obtained for petsc-3.1-p7:
>>>> config.compilers(/cygdrive/d/Dev/petsc-3.1-p7/config/BuildSystem/config/compilers.py:1084)
>>>> config.compilers(config/BuildSystem/config/compilers.py:1084)
>>>> modules
>>>>          Pushing language FC
>>>> sh: /cygdrive/d/Dev/petsc-3.1-p7/bin/win32fe/win32fe ifort -c -o
>>>> conftest.o  -MT -Z7 -fpp  conftest.F
>>>> Executing: /cygdrive/d/Dev/petsc-3.1-p7/bin/win32fe/win32fe ifort -c -o
>>>> sh:
>>>>          Pushing language FC
>>>> conftest.o -Iconfdir  -MT -Z7 -fpp  conftest.F
>>>> sh:
>>>>                  Pushing language FC
>>>>                  Popping language FC
>>>> sh: /cygdrive/d/Dev/petsc-3.1-p7/bin/win32fe/win32fe ifort  -o
>>>> conftest.exe   -Iconfdir  -MT -Z7 -fpp  conftest.o configtest.o
>>>> Executing: /cygdrive/d/Dev/petsc-3.1-p7/bin/win32fe/win32fe ifort  -o
>>>> sh: LINK : D:\Dev\PETSC-~2.1-P\conftest.exe not found or not built by the
>>>>          Popping language FC
>>>> The compiler I used is the same I use for petsc-3.2-p1.
>>>> The difference is in the paths where you try to build this tests. As far
>>>> as I understand for petsc-3.1-p7 you used local directory and for
>>>> petsc-3.2-p1 temp directory is used.
>>>> Could it be the reason?
>>>   That would be broken behavior from ifort, but I guess it is possible. I
>>> will talk with Satish about how
>>> this should really be fixed. For right now, go to
>>>   to the checkFortranModuleInclude() function and comment out the last two
>>> lines, which are killing the configure.
>>> Your build will break on the Fortran modules (I assume), but everything
>>> else should work.
>>>     Thanks,
>>>         Matt
>>>>   Regards,
>>>>   Alexander
>>>> On 15.09.2011 14:54, Matthew Knepley wrote:
>>>> On Thu, Sep 15, 2011 at 2:49 AM, Alexander Grayver<
>>>>> Hello,
>>>>> I hope you are having nice day!
>>>>> I have been using petsc-3.1-p7 under windows for 6 months and now decided
>>>>> to get new version. I used my old configure line which was successful for
>>>>> petsc-3.1:
>>>>> ./config/configure.py --PETSC_DIR=/cygdrive/d/dev/petsc-3.2-p1
>>>>> --with-petsc-arch=cygwin-cxx-debug-fortran --with-fortran-interfaces=1
>>>>> --with-cc='win32fe cl' --with-fc='win32fe ifort'  --with-cxx='win32fe cl'
>>>>> --with-windows-graphics=0 --download-f-blas-lapack=1 --with-precision=double
>>>>> --with-scalar-type=complex --with-clanguage=cxx
>>>>> --with-mpi-include="/cygdrive/d/Dev/HPC_2008_SDK/Include"
>>>>> --with-mpi-lib=["/cygdrive/d/Dev/HPC_2008_SDK/Lib/amd64/msmpi.lib","/cygdrive/d/Dev/HPC_2008_SDK/Lib/amd64/msmpifec.lib"]
>>>>> --useThreads=0
>>>>> But unfortunately it doesn't work properly anymore, even though my
>>>>> development environment has not been changed. The error is:
>>>>>          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for
>>>>> details):
>>>>> Please find configure.log attached.
>>>>   The problem here is that your Fortran compiler reports that is supports
>>>> F90, but cannot
>>>> locate modules using an include path. This will make parts of the PETSc
>>>> build fail. Do you
>>>> know what flag it uses? I try -I, -p, and -M.
>>>>     Thanks,
>>>>        Matt
>>>>> Regards,
>>>>>   Alexander
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to which their
>>>> experiments lead.
>>>> -- Norbert Wiener
>>> experiments lead.
>>> -- Norbert Wiener
Type: application/x-zip-compressed
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110915/b44e52df/attachment-0001.bin>
