[petsc-users] Problems with last PETSC-3.2 release on Windows
Alexander Grayver
agrayver at gfz-potsdam.de
Thu Sep 15 08:43:49 CDT 2011
Thanks Matt,
I will that, but I use PETSC from Fortran so I need Fortran functionality.
Alexander
On 15.09.2011 15:43, Matthew Knepley wrote:
> On Thu, Sep 15, 2011 at 8:01 AM, Alexander Grayver
> <agrayver at gfz-potsdam.de <mailto:agrayver at gfz-potsdam.de>> wrote:
> Matthew,
> I found this check in configure.log I obtained for petsc-3.1-p7:
> TEST checkFortranModuleInclude from
> config.compilers(/cygdrive/d/Dev/petsc-3.1-p7/config/BuildSystem/config/compilers.py:1084)
> TESTING: checkFortranModuleInclude from
> config.compilers(config/BuildSystem/config/compilers.py:1084)
> Figures out what flag is used to specify the include path for
> Fortran modules
> Pushing language FC
> sh: /cygdrive/d/Dev/petsc-3.1-p7/bin/win32fe/win32fe ifort -c -o
> conftest.o -MT -Z7 -fpp conftest.F
> Executing: /cygdrive/d/Dev/petsc-3.1-p7/bin/win32fe/win32fe ifort
> -c -o conftest.o -MT -Z7 -fpp conftest.F
> sh:
> Pushing language FC
> conftest.o -Iconfdir -MT -Z7 -fpp conftest.F
> -c -o conftest.o -Iconfdir -MT -Z7 -fpp conftest.F
> sh:
> Pushing language FC
> Popping language FC
> sh: /cygdrive/d/Dev/petsc-3.1-p7/bin/win32fe/win32fe ifort -o
> conftest.exe -Iconfdir -MT -Z7 -fpp conftest.o configtest.o
> -o conftest.exe -Iconfdir -MT -Z7 -fpp conftest.o configtest.o
> sh: LINK : D:\Dev\PETSC-~2.1-P\conftest.exe not found or not built
> by the last incremental link; performing full link
> compilers: Fortran module include flag -I found
> Popping language FC
> The compiler I used is the same I use for petsc-3.2-p1.
> The difference is in the paths where you try to build this tests.
> As far as I understand for petsc-3.1-p7 you used local directory
> and for petsc-3.2-p1 temp directory is used.
> Could it be the reason?
> That would be broken behavior from ifort, but I guess it is possible.
> I will talk with Satish about how
> this should really be fixed. For right now, go to
> to the checkFortranModuleInclude() function and comment out the last
> two lines, which are killing the configure.
> Your build will break on the Fortran modules (I assume), but
> everything else should work.
> Thanks,
> Matt
> Regards,
> Alexander
> On 15.09.2011 14:54, Matthew Knepley wrote:
>> On Thu, Sep 15, 2011 at 2:49 AM, Alexander Grayver
>> Hello,
>> I hope you are having nice day!
>> I have been using petsc-3.1-p7 under windows for 6 months and
>> now decided to get new version. I used my old configure line
>> which was successful for petsc-3.1:
>> ./config/configure.py
>> --PETSC_DIR=/cygdrive/d/dev/petsc-3.2-p1
>> --with-petsc-arch=cygwin-cxx-debug-fortran
>> --with-fortran-interfaces=1 --with-cc='win32fe cl'
>> --with-fc='win32fe ifort' --with-cxx='win32fe cl'
>> --with-windows-graphics=0 --download-f-blas-lapack=1
>> --with-precision=double --with-scalar-type=complex
>> --with-clanguage=cxx
>> --with-mpi-include="/cygdrive/d/Dev/HPC_2008_SDK/Include"
>> --with-mpi-lib=["/cygdrive/d/Dev/HPC_2008_SDK/Lib/amd64/msmpi.lib","/cygdrive/d/Dev/HPC_2008_SDK/Lib/amd64/msmpifec.lib"]
>> --useThreads=0
>> But unfortunately it doesn't work properly anymore, even
>> though my development environment has not been changed. The
>> error is:
>> UNABLE to CONFIGURE with GIVEN OPTIONS (see
>> configure.log for details):
>> Cannot determine Fortran module include flag
>> Please find configure.log attached.
>> The problem here is that your Fortran compiler reports that is
>> supports F90, but cannot
>> locate modules using an include path. This will make parts of the
>> PETSc build fail. Do you
>> know what flag it uses? I try -I, -p, and -M.
>> Thanks,
>> Matt
>> Regards,
>> Alexander
>> experiments is infinitely more interesting than any results to
>> which their experiments lead.
>> -- Norbert Wiener
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110915/22d9755a/attachment-0001.htm>
