[petsc-users] petsc-users Digest, Vol 33, Issue 13
Sean Farley sean at mcs.anl.gov
Wed Sep 7 13:35:20 CDT 2011
> Okay, I will do that, but do I need to carry all  MUMPS and PETSc
> libraries  when I try to run the executables in a cluster or some other
> computer which will not have PETSc or MUMPS installed? I do not plan on
> building PETSc and MUMPS again in some computer in the national lab. I am
> planning on sending the executable only from my laptop to the cluster. Is
> this possible?
If that is possible, then you should update the wiki page:
http://en.wikipedia.org/wiki/Execution_(computing)
Sean
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110907/fe593044/attachment.htm>
