[petsc-users] petsc-users Digest, Vol 33, Issue 13
amrit poudel
amrit_pou at hotmail.com
Wed Sep 7 13:29:04 CDT 2011
Okay, I will do that, but do I need to carry all MUMPS and PETSc libraries when I try to run the executables in a cluster or some other computer which will not have PETSc or MUMPS installed? I do not plan on building PETSc and MUMPS again in some computer in the national lab. I am planning on sending the executable only from my laptop to the cluster. Is this possible?
Thanks for your help !
-Amrit
Date: Wed, 7 Sep 2011 18:20:15 +0000
To: petsc-users at mcs.anl.gov
Subject: Re: [petsc-users] petsc-users Digest, Vol 33, Issue 13
I do not plan on using MUMPS without PETSc, but I would like to learn how I can compile these libraries independent of PETSc so that later when I try to configure PETSc in some other computer I know how to take care of MUMPS libraries. Coming to think of it, it sounds like I should not be doing this, because the other computer (which will be a cluster since this is where I plan on doing my number crunching ultimately) will have different OS and I will be out of luck again.
Then just use --download-mumps. BuildSystem will use the cluster provided MPI (or the mpi you have on your system) and build the external libraries correctly.
Sean
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110907/02da76e1/attachment.htm>
