[petsc-users] petsc-users Digest, Vol 33, Issue 13
Sean Farley
sean at mcs.anl.gov
Wed Sep 7 13:20:15 CDT 2011
> I do not plan on using MUMPS without PETSc, but I would like to learn how I
> can compile these libraries independent of PETSc so that later when I try to
> configure PETSc in some other computer I know how to take care of MUMPS
> libraries. Coming to think of it, it sounds like I should not be doing this,
> because the other computer (which will be a cluster since this is where I
> plan on doing my number crunching ultimately) will have different OS and I
> will be out of luck again.
Then just use --download-mumps. BuildSystem will use the cluster provided
MPI (or the mpi you have on your system) and build the external libraries
correctly.
Sean
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110907/24db1a8a/attachment.htm>
