[petsc-users] Block ILU with AIJ matrix?
Mon Oct 31 05:46:43 CDT 2011
On Mon, Oct 31, 2011 at 8:15 AM, Gong Ding <gdiso at ustc.edu> wrote:
> Yes, modern direct solver do block factorization as super node method.
> Can ASM type preconditioner use superlu ILUT on each subdomain?
Yes.
   Matt
> At preset, my solver (BCGS) only works with ASM+ILU(1) on a "smart
> partitioned" mesh.
> > The ILUTP in SuperLU (4.2 and up) exploits blocking (supernodes) in
> > the (approximate) L & U factors.  Note the block boundary is
> > discovered on the fly, which is usually larger than the block size
> > from the input matrix A.  So the efficiency is pretty good.  It uses
> > threshold dropping with partial pivoting, numerically is quite good
> > too.    It's available only in the serial version.
> > Sherry Li
> > On Sun, Oct 30, 2011 at 11:18 PM, Jed Brown <jedbrown at mcs.anl.gov>
> wrote:
> > > On Sun, Oct 30, 2011 at 23:50, Gong Ding <gdiso at ustc.edu> wrote:
> > >> I had also considered use max block size. But it is not efficient
> here.
> > >> Hope petsc support nonuniform block size one day.
> > > Inodes do a sort of partial blocking. There has to a clear performance
> > > benefit to explicit variable blocking in order to justify the
> implementation
> > > and interface complexity. I have not yet seen a demonstration of this.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111031/45ad34a7/attachment.htm>
