[petsc-users] Block ILU with AIJ matrix?
    Gong Ding
    gdiso at ustc.edu
    Mon Oct 31 03:15:41 CDT 2011
Yes, modern direct solver do block factorization as super node method.
Can ASM type preconditioner use superlu ILUT on each subdomain?
At preset, my solver (BCGS) only works with ASM+ILU(1) on a "smart partitioned" mesh.
> The ILUTP in SuperLU (4.2 and up) exploits blocking (supernodes) in
> the (approximate) L & U factors.  Note the block boundary is
> discovered on the fly, which is usually larger than the block size
> from the input matrix A.  So the efficiency is pretty good.  It uses
> threshold dropping with partial pivoting, numerically is quite good
> too.    It's available only in the serial version.
> Sherry Li
> On Sun, Oct 30, 2011 at 11:18 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> > On Sun, Oct 30, 2011 at 23:50, Gong Ding <gdiso at ustc.edu> wrote:
> >> I had also considered use max block size. But it is not efficient here.
> >> Hope petsc support nonuniform block size one day.
> > Inodes do a sort of partial blocking. There has to a clear performance
> > benefit to explicit variable blocking in order to justify the implementation
> > and interface complexity. I have not yet seen a demonstration of this.
